blown head gasket
Old Mar 19, 2007 | 07:21 PM
rippinitup01's Avatar
Default blown head gasket
i have a 2000 si running 8psi on stock motor and i was at full boost then shifted in to fourth and whenn i got to bout 5-6000rpm the motor stoped pulling and huge white cloud was behind my car and the car smoked white heavy only in acceleration but not just cruising. oil was sprayed out from the head gasket on one side and white smoke comes out of the breather on the vavle cover..
wat should i get i know obviously a New head gasket wat what brand
and should i go ahead and do ARP head studs?
and now it idles like **** hole
Old Mar 19, 2007 | 07:39 PM
ke98248's Avatar
Default Re: blown head gasket (rippinitup01)
turn it off immediately and drive as little as possible. you may have warped the head, and in that case, you will need a shop to resurface that baby... Or else you'll keep blowing those headgaskets.
Old Mar 19, 2007 | 07:41 PM
onesikdb8's Avatar
Stock headgasket and ARP studs and definitely have your head decked. Check your block with a straight edge also.
Good Luck.
Old Mar 19, 2007 | 07:42 PM
highrev1987's Avatar
Default Re: blown head gasket (onesikdb8)
Oem Three layer on my boostie
lifesastruggle
Engine Management and Tuning
Feb 15, 2017 03:22 AM
Tong.Y
Jun 5, 2011 09:17 PM
draperj09
14
Mar 28, 2007 09:50 PM
JTCdudeman
Sep 29, 2005 05:42 AM
youngkow
Dec 26, 2003 08:40 PM
