eg auto to manual swap using stock manual mount
Old Mar 19, 2007 | 03:45 PM
6shootahorsenamedtrigga's Avatar
Default eg auto to manual swap using stock manual mount
I picked up a 93 automatic sedan shell to use whenever my dd car will be down for work. I have a full manual d16 and I know that you are suppose to use an aftermarket mount designed for the swap bc the welded bracket is different. However I don't care about this car much so is it possible to use the oem manual mount? I don't care if the engine sits higher on that side. I just want to know if it will work until I have extra cash for that mount. Only those who have attempted this exact move should chime in; no hearsay. TIA
Old Mar 19, 2007 | 03:58 PM
Luserkid's Avatar
Default Re: eg auto to manual swap using stock manual mount (6shootahorsenamedtrigga)
If you use a stock mount itll sit crooked and can cause axle failure. I wouldnt do it.
vestalfootball72
Guest
Posts: n/a
when i did the swap, I just drilled out the spot welds and welded on the manual mount a litle bit back.
Old Mar 19, 2007 | 04:09 PM
Default Re: eg auto to manual swap using stock manual mount (vestalfootball72)
yeah ive done that with the oem bracket on a different car and wanted to avoid that...
but it will def cause axle failure? is this from experience or what
Old Mar 19, 2007 | 04:11 PM
borenshoratius's Avatar
when i did mine i tried shims but it still never sat right so i just drilled out the spot welds and put in a manual mount always heard axles when i shimmed when turning
Old Mar 19, 2007 | 04:31 PM
Default Re: eg auto to manual swap using stock manual mount (borenshoratius)
hey thanks for that input..i was actually thinking about something like that...longer studs if need be and use a nut as a shim to lower the motor... when the axle made noise did it ever end up breaking...cuz this would just be temporary until i can afford that swap mount
lazymbf
11
Jul 15, 2025 03:17 PM
Jason913
29
Dec 27, 2011 07:48 AM
elmejor
Jun 18, 2008 07:04 PM
getnasty
Nov 17, 2005 12:56 PM
