rear wheel bearing
hey all,
i have a 93 si hatch with some bad rear wheel bearing is mess up. i can hear it when the car is rolling. my question is will it be hard to replace it? or is it better to bring it to the shop? will i have to use a machine to press anything? thank you!
pull the wheel off, pull the metal cover off the center of the hub, knock the big nut off and the hub will come off, bring it to a machine shop with a new bearing, have them press it in and then put it back together.
Yes you can buy a hub bearing assembly. Many people recomend it actually. Look around at some different auto part stores for them. They should be close to $100 per side for the part but they're not hard to change by yourself.
http://www.d-series.org/forums...39296
PaChiLa Leader
Feb 18, 2009 05:21 PM
Streetneon2185
Jun 5, 2007 09:39 PM
Hemix
10
Mar 5, 2007 06:12 PM
