Culprits for VTEC not working properly....wat are they?
Old Mar 19, 2007 | 01:57 PM
1JDMDOMINICAN's Avatar
Default Culprits for VTEC not working properly....wat are they?
Like the post says, my brother in law's 95 GSR has no VTEC. For some reason today it stopped working. Problem is, we cant figure out what it is because the car is not turning on the check engine light and its not flashing any codes. My question is, wat else could cause VTEC not to work. I dont think it would be the VTEC solenoid itself because those arent a common to go bad.....
Can anyone point is in the right direction as to what it could be?
Thanx guys.
Old Mar 19, 2007 | 02:01 PM
awdgsx96's Avatar
Default Re: Culprits for VTEC not working properly....wat are they? (1JDMDOMINICAN)
Engine temp too low, not enough oil pressure, engine has to be at a certain RPM, clogged vtec solenoid screen
Old Mar 19, 2007 | 02:20 PM
bkmc24's Avatar
Default Re: Culprits for VTEC not working properly....wat are they? (awdgsx96)
Low oil? thats what it was for me.
Old Mar 19, 2007 | 02:50 PM
doood's Avatar
been there done that
Default Re: Culprits for VTEC not working properly....wat are they? (bkmc24)
how do you know it's not working?
there are certain conditions before vtec will engage:
- engine up to temp
- above certain throttle position
- enough oil pressure
- above certain speed
and some more im probably forgetting
Old Mar 19, 2007 | 04:52 PM
mobgsr's Avatar
yea i'd check that oil level first
Old Mar 19, 2007 | 04:55 PM
DraginTeg93's Avatar
clogged vtec solenoid screen .. how do you check that and how to fit it ? just wondering
Old Mar 19, 2007 | 05:41 PM
awdgsx96's Avatar
Default Re: Culprits for VTEC not working properly....wat are they? (DraginTeg93)
Ummmm I'm not entirely sure, I've only seen it done a couple of times. I'm remembering it being pretty straight forward, you take off the vtec solenoid and there is a little screen in there. Its like a secondary oil filter, and I'm assuming it is where the oil line goes into the solenoid or something to that effect.
Old Mar 19, 2007 | 08:31 PM
99Geeezer's Avatar
Unplug and unbolt the solenoid by the valve cover. The gasket will have a mesh screen imbedded. Make sure it is clear of debris. When clean, re install and see if you have VTEC again.
Old Mar 20, 2007 | 01:45 PM
Well, we put more oil in it cuz it was low, but the VTEC still did not engage. So now, I do not know wat it is...I'm going to take off the solenoid and clean it and see what happens.
Old Mar 20, 2007 | 02:03 PM
awdgsx96's Avatar
Default Re: (1JDMDOMINICAN)
Def clean the screen and post back. But, was the oil recently flushed, if not, dirty oil might be the culprit.
BlueSmartEm1
13
Jul 3, 2011 09:26 PM
gsrboost737
Aug 7, 2008 06:38 AM
502em1
13
Apr 18, 2007 10:53 AM
J's GS-R
Feb 23, 2006 06:14 PM
95 GSR B20VTEC
Jul 25, 2002 01:08 PM
