knock sensor question
Old Mar 18, 2007 | 08:54 PM
battleREADYb20's Avatar
Default knock sensor question
ok i have a 90 si hatch with Jdm b16. i have all the vtec wired up to the ecu. and i bypassed the knock sensor by using a thing found on h-t. anyways im driving and it starts to throw the speed sensor code. i check the cable it broken. will that cause the vtec not to engage?i bought a replacment and will put it in tommrow. but was wondering if that could be why. also if im using a vtec controller. is the knock sensor needed for vtec to work? or will it work off the vafc?
Old Mar 19, 2007 | 12:43 PM
anyone?
Old Mar 19, 2007 | 12:48 PM
EF_LSVtec's Avatar
Default Re: (battleREADYb20)
you don't need knock sensor for vtec to work, although you need to take care of the VSS code...Although, I was using a Stage 2 hondata at the time and there may be a knock sensor delete option.
Old Mar 19, 2007 | 01:29 PM
the vss code? what is that? the speed sensor? if so i just replaced it today. so you saying i can run vtec off the vafc without the knock sensor?
SingleCamin
May 19, 2009 08:23 AM
b18cEF9
Dec 20, 2004 04:22 PM
codeh22a4
Apr 8, 2004 12:51 AM
justinlude
Jan 31, 2002 12:17 PM
