WAshing your car. THe Proper way
So i just bought a new civic and i want to make sure the paint will be Efin clean. (period) i need the good **** not crappy products.
so far i went out to the store today and got a bucket. bought 1 Need another one for the rinse process. go Meguiers step 2 (polish) and step 3 carnabula wax) will be going back for step one( cleaning the surface) ( not sure if i really need it tho) i bougth some microfiber towls but they are wash towls. i need some DRying towls and some polishing, waxing towls. also for the WAsh i bought Turtle Wax ice car wash. Hopeflly this will make the car look even better then new.
so what do you use. any tips on washing polishing waxing? any info will be much appreciated. thanks
while meguiars is by no means shitty, it is certainly not "the good ****" either. at least not the 3 step detailing system.
check out this thread
https://honda-tech.com/zerothread?id=1782397
edit
and this one
https://honda-tech.com/zerothread?id=790409
edit
and this one
https://honda-tech.com/zerothread/1782397 that thread pretty much did the trick.
aww....brian beat me to it.
If you want information you need to go straight to the source. http://www.meguiarsonline.com
BAR NONE NO QUESTIONS
ok so basically polishing takes off your clear coat . making the car nicer looing. but wont that result in very low clear coat over a few years?
is so im thinking about skipping polishing and just buying a cleaner ( still have to do some research on them) and then just waxing.
If you skip the polishing part you will not get rid of your swirl marks. The whole point of the polishing is the even out the paint to remove swirl marks and fine scratches from your car. Do some research on meguiarsonline forum and you will find a wealth of knowledge from professionals.
1. Wash
2. Clay
3. Prep
4. Polish/Cleaner
5. Seal
1. Wash
2. Clay
3. Prep
4. Polish/Cleaner
5. Seal
i-VTEC_DOHC
Honda Civic (2006 - 2015)
10
Jun 3, 2008 05:45 PM
