T3/GT40 good for a mild setup?
Hi all,
I am trying to decide which turbo I should go with. I'm running 9:1 wiseco pistons, H beam rods and some reinforced valve terrain in a B16A. Looking to make around 300 hp daily and around 400 at the track.. Would a T3/GT40 be a good set up? If not what would be the optimal turbo? I've been told the T3/T04E would be the best bang for the buck for what i'm shooting for..
a t3/t04e 50 or 60 trim would meet your power goals and not cost you that much.
the t3/gt40 is a little laggy especially on a B16 and is a little more money compared to the t3/t04e's.
if you dont care about price then try a gt30 or something similar.....
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by non-VTEC »</TD></TR><TR><TD CLASS="quote">a t3/t04e 50 or 60 trim would meet your power goals and not cost you that much.
correct on that. But don't do the opposite extreme by getting something TOO SMALL to do the same hp either. That would cause a bit of inefficiency and heat, as well.
</TD></TR></TABLE>correct on that. But don't do the opposite extreme by getting something TOO SMALL to do the same hp either. That would cause a bit of inefficiency and heat, as well.
Mugencrxsir1
Feb 26, 2006 04:17 PM
