What color is my remote signal line?
Old Mar 18, 2007 | 09:34 AM
Jay J's Avatar
Prince of Zamunda
Default What color is my remote signal line?
Well its time I guess for my car to get its audio stuff done right, as I just bought a cage/ ground strap for it... and an amp....
Its a JVC HU KDSX780. There's a blue line that has antenna power written on it? Is that the line that I need to splice into to have power signal/switch turn-on for my Amp?
Sorry for the crappy quality. I just used windows picture resizer and ripped Jpegs off of raw's.
Modified by Jay J at 11:01 AM 3/18/2007
Old Mar 18, 2007 | 10:03 AM
Jay J's Avatar
Prince of Zamunda
Default Re: What color is my remote signal line? (Jay J)
Help?
Old Mar 18, 2007 | 10:04 AM
02 accord's Avatar
Remote should be blue with a white stripe.
Old Mar 18, 2007 | 10:19 AM
Jay J's Avatar
Prince of Zamunda
Default Re: What color is my remote signal line? (02 accord)
there's one on the vehicle's harness but not on the radio harness
Old Mar 18, 2007 | 10:26 AM
B18C_EJ8's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote &raquo;</TD></TR><TR><TD CLASS="quote">There's a blue line that has antenna power written on it? Is that the line that I need to splice into to have power signal/switch turn-on for my Amp?</TD></TR></TABLE>
Yes...
And if you look at the white plug that connects to the car's harness, there's probably not even a wire coming out of the car's connector that the blue wire from the deck goes to...
Old Mar 18, 2007 | 10:59 AM
EBP_SI's Avatar
Default Re: (B18C_EJ8)
can i ask what that clusterfuck of electical tape is?
Old Mar 18, 2007 | 11:02 AM
B18C_EJ8's Avatar
Default Re: (EBP_SI)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by EBP_SI &raquo;</TD></TR><TR><TD CLASS="quote">can i ask what that clusterfuck of electical tape is?</TD></TR></TABLE>
Um, I think you answered your own question with the word "clusterfuck".
Old Mar 18, 2007 | 11:10 AM
EBP_SI's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by B18C_EJ8 &raquo;</TD></TR><TR><TD CLASS="quote">
Um, I think you answered your own question with the word "clusterfuck". </TD></TR></TABLE>
so sad that people think electrical tape is an adequate method of connecting wires..
Old Mar 18, 2007 | 11:13 AM
Jay J's Avatar
Prince of Zamunda
Actually its soldered under neath,then all the wires were taped; and lastly taped together..The previous owner did a mess of the wiring. I'm trying to fix it
Old Mar 18, 2007 | 11:37 AM
EBP_SI's Avatar
Default Re: (Jay J)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Jay J &raquo;</TD></TR><TR><TD CLASS="quote">Actually its soldered under neath,then all the wires were taped; and lastly taped together..The previous owner did a mess of the wiring. I'm trying to fix it</TD></TR></TABLE>
well if you're soldering the wires, you should be putting heat shrink over it. electrical tape wont stand the test of time for an insulator especially with the heat inside of a car.
Old Mar 18, 2007 | 12:36 PM
Jay J's Avatar
Prince of Zamunda
It was soldered by the previous owner, should I unclip them from the harness then shrink em?
Old Mar 18, 2007 | 12:48 PM
EBP_SI's Avatar
Default Re: (Jay J)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Jay J &raquo;</TD></TR><TR><TD CLASS="quote">It was soldered by the previous owner, should I unclip them from the harness then shrink em? </TD></TR></TABLE>
i would redo the whole harness. cut out the old connections, restrip them, solderthem and heat shrink them.
Old Mar 18, 2007 | 01:07 PM
sprkn1's Avatar
so your running the power line from your cd player to your amp, why not just wire it straight to the battery...
Old Mar 18, 2007 | 01:08 PM
Jay J's Avatar
Prince of Zamunda
Default Re: What color is my remote signal line? (sprkn1)
The Amp is wired to the battery but what's the remote turn on lead color? I thought it was blue like Alpine HU's..? but my blue wire says antenna power?
Old Mar 18, 2007 | 01:34 PM
sprkn1's Avatar
check the blue wire that is striped, if you take all the tape off and you should find a wire that isnt connected to anything. the wiring harness i have has a label amp remote and is heatshrinked. this is for a sony cd player...
Old Mar 18, 2007 | 05:36 PM
Jay J's Avatar
Prince of Zamunda
I've installed an amp in 3 vehicles.. Surprisingly mine is the PITA one... Where I can't distinguish one wire to the next
Old Mar 18, 2007 | 08:24 PM
wrx-killer-Sti-eater's Avatar
From: 99 probs but a stolen car aint 1, ca, cerritos/fullerton
First the color from all name brand headunits and most out there use a standered for wire color. Some headunits have a remote lead and a amp lead. blue will be ant lead and blue/white will be the amp turn on. If there is only one blue/white wire for the antenna use that wire to power both the amp and the power atenna.
Second..... Why does that harness on the radio not match the wire that you are using and showing pictures of that are supppose to be the raido harness wires?
Old Mar 19, 2007 | 05:03 AM
Jay J's Avatar
Prince of Zamunda
Default Re: What color is my remote signal line? (wrx-killer-Sti eater)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by wrx-killer-Sti eater &raquo;</TD></TR><TR><TD CLASS="quote">First the color from all name brand headunits and most out there use a standered for wire color. Some headunits have a remote lead and a amp lead. blue will be ant lead and blue/white will be the amp turn on. If there is only one blue/white wire for the antenna use that wire to power both the amp and the power atenna.
Second..... Why does that harness on the radio not match the wire that you are using and showing pictures of that are supppose to be the raido harness wires?</TD></TR></TABLE>
Which wires?
Old Mar 20, 2007 | 05:46 AM
jz98ctr's Avatar
why don't you simply use the legend on the top of the radio that tells you which wire does what function???
dravesef
Audio / Security / Video
Jul 15, 2008 05:49 PM
MilanoCivic97
May 1, 2006 01:25 PM
jdmaek
Jan 9, 2005 11:15 PM
jlc-bigj
Jun 4, 2004 05:24 AM
type rizzy
Jul 6, 2002 04:52 PM
