Amp in protection mode........
Old Mar 19, 2007 | 05:01 PM
bonta-kun's Avatar
Default Amp in protection mode........
i got a amp as a hand me down from a friend its nothing baller or anyhitng liek that and it seems to be old
but it is a rockwood 4ch 600 wat amp
when we got it we hooked it up to my friends car which has had a system for over a year to test it out
this car has a rockford fostgate punch p1
it sounded pretty good for a while but kinda low so we turned the gains up
this specific amp is weird it has a button to bridge the chanels unlike newer ones were u separate the chanels
so we turned the gain down and bridged the amp once we did this it went in to protection mode and the sub woofer made a low hit sound and sounds like a heart beat while doing this the protection light blinks on and off
i moved this amp into my car and it still continues with the same type of deal
i have tried the amp with just the ground remote and 12 volt
with no success
any suggestions sorry its so long
Old Mar 19, 2007 | 05:05 PM
01d17's Avatar
Default Re: Amp in protection mode........ (bonta-kun)
probably by pressing that button you talked about it dropped the ohm load of the speaker and fried the internals. that amp is probably done for.
Old Mar 20, 2007 | 05:22 AM
jz98ctr's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by bonta-kun &raquo;</TD></TR><TR><TD CLASS="quote">i got a amp as a hand me down from a friend... it seems to be old </TD></TR></TABLE>
problem #1
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by bonta-kun &raquo;</TD></TR><TR><TD CLASS="quote">but it is a rockwood 4ch 600 wat amp</TD></TR></TABLE>
ok...THIS is problem #1 ....and it is no where near 600 watts
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by bonta-kun &raquo;</TD></TR><TR><TD CLASS="quote">i have tried the amp with just the ground remote and 12 volt
with no success </TD></TR></TABLE>
unless it has fuses on the amp itself that are blown......it's fubarred!
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by bonta-kun &raquo;</TD></TR><TR><TD CLASS="quote">any suggestions </TD></TR></TABLE>
throw that amp in the trash or you can use it for a paperweight or to even out that wobbly table you have.....and get a real amp... not a half kenwood/ half rockford
Old Mar 20, 2007 | 07:51 AM
nsxxtreme's Avatar
This is your problem, it would probably be better used to stick under your tire to keep your car from rolling.
Seriously throw it away and buy something else.
SiBuddy00
Audio / Security / Video
Apr 15, 2009 05:02 PM
mmajedi
Nov 5, 2007 08:45 AM
Orpheus1985
Jul 21, 2005 07:15 AM
blindO
May 30, 2005 07:21 AM
