Anyone ever had this happen before?
Old Mar 17, 2007 | 04:23 PM
ILcrxsi1's Avatar
I tell doctors what to do
Default Anyone ever had this happen before?
We were replacing a radiator on a car today that supposedly had a cracked radiator. We then went to bleed the coolant with a dummy reservoir in place of the radiator cap. On start-up the radiator shot coolant out of the top of the radiator all over the engine and car. I'm talking with force too. But anyway we kept bleeding.
After it all seemed bled we turned it off and put the radiator cap back on. Started it up and it blew the heater hose off the block. Drenching the entire motor again. I'm guessing headgasket, but I've never seen one this bad before.
Old Mar 17, 2007 | 05:00 PM
dr_latino999's Avatar
Default Re: Anyone ever had this happen before? (ILcrxsi1)
Wow, sure the sleeve is still around the piston? That's a lot of force my friend.
Old Mar 17, 2007 | 07:05 PM
gator88's Avatar
Default Re: Anyone ever had this happen before? (dr_latino999)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ILcrxsi1 &raquo;</TD></TR><TR><TD CLASS="quote">We were replacing a radiator on a car today that supposedly had a cracked radiator. We then went to bleed the coolant with a dummy reservoir in place of the radiator cap. On start-up the radiator shot coolant out of the top of the radiator all over the engine and car. I'm talking with force too. But anyway we kept bleeding.
After it all seemed bled we turned it off and put the radiator cap back on. Started it up and it blew the heater hose off the block. Drenching the entire motor again. I'm guessing headgasket, but I've never seen one this bad before.</TD></TR></TABLE>
DAMN!!!!
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by dr_latino999 &raquo;</TD></TR><TR><TD CLASS="quote"> That's a lot of force my friend.</TD></TR></TABLE>
Old Mar 18, 2007 | 09:04 AM
IndySporty's Avatar
I have seen a cracked sleeve that wasn't even that bad hehehe
Old Mar 18, 2007 | 09:52 AM
ILcrxsi1's Avatar
Default Re: (IndySporty)
The odd thing is that except for overheating, the car doesn't really run bad. When you open the bleeder valve exhaust comes pouring out of it like a volcano.
Old Mar 18, 2007 | 09:59 AM
HondaHeddie's Avatar
Default Re: (ILcrxsi1)
blocked water path?
rust filled heater core
thermostat somehow sealed up?
just wild guesses
Old Mar 18, 2007 | 10:39 AM
sirtef9's Avatar
Default Re: (HondaHeddie)
My car did that exact same thing, turned out to be the head gasket
Old Mar 29, 2007 | 03:14 PM
90JPRCRX's Avatar
Smells like Tuna
Default Re: (sirtef9)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by sirtef9 &raquo;</TD></TR><TR><TD CLASS="quote">My car did that exact same thing, turned out to be the head gasket</TD></TR></TABLE>
i think thats what it is
this was my car, and dam we made a mess. wasted all the coolant, painted the motor 3 coats with it. then drove it back to my house across joliet, and it was a freaking smoke bomb. everybody was staring.
then the other day i drove it through two subdivisions, it warmed up before i got to point B, but never overheated. drove fine with no problems.
so i dunno, doesn't matter anyway, its gettin trans and motor swapped
Skeetzy
19
Nov 14, 2016 08:51 AM
c1_sleeper
Jul 20, 2006 07:57 AM
slikz714
Jul 12, 2006 03:40 AM
missionaryrider
Jun 21, 2005 09:19 PM
tkHBseries
Feb 19, 2005 06:48 PM
