Alpine Type R 6.5 " components in CRX doors
Old Mar 17, 2007 | 01:38 PM
CoolRedXylophone's Avatar
Default Alpine Type R 6.5 " components in CRX doors
Im having trouble getting these to fit because the window guide is in the way. Is there a way to get these in? Thanks
Old Mar 17, 2007 | 03:15 PM
fcm's Avatar
fcm
Old Fart
Default Re: Alpine Type R 6.5 " components in CRX doors (CoolRedXylophone)
Yes, you have to replace the stock plastic speaker housings with custom MDF housings, you may even have to space the front window guide back a little.
Or you can go the ghetto route and use depth reducer/spacers. 94
Old Mar 17, 2007 | 08:17 PM
Default Re: Alpine Type R 6.5 " components in CRX doors (fcm)
plastic speaker housing? all i see is a hole in the door metal. how would one go about making a MDF housing, and could the stock plastic speaker cover fit over it?
also, i found these, http://www.crutchfield.com/S-H...27802
but would they help me at all?
sorry for my noobness, but thanks very much for the help
Modified by CoolRedXylophone at 9:39 PM 3/17/2007
Old Mar 18, 2007 | 07:39 AM
fcm's Avatar
fcm
Old Fart
They are rear speaker brackets for the 88-91 CRX.
The should look something like this... http://cgi.ebay.com/ebaymotors...QrdZ1
What was in the doors when you pulled the door panel, were they aftermarket speakers, are there screw holes other then the stock ones around the speaker opening? 94
Old Mar 18, 2007 | 08:36 AM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by fcm &raquo;</TD></TR><TR><TD CLASS="quote">They are rear speaker brackets for the 88-91 CRX.
What was in the doors when you pulled the door panel, were they aftermarket speakers, are there screw holes other then the stock ones around the speaker opening? 94</TD></TR></TABLE>
the plastic housing for the 5.25" speakers had been removed and 6.5" Honda speakers were there held in with 3 screws i believe. im going to remove the door paneling to try to get a better idea of what you are suggesting. im just having trouble picturing it. thanks for the help
Old Mar 18, 2007 | 09:36 AM
MilanoCivic97's Avatar
to fit them in my ej8 i had to enlarge the hole in the door metal a bit. then i made a 3/4" mdf spacer and screwed them right into that. the plastic speaker cover fit with slight modification with a dremel...not much though.
770_dc2
Audio / Security / Video
Feb 15, 2011 04:08 PM
SECURITY
Aug 5, 2005 04:39 AM
crx98
Oct 22, 2003 06:15 AM
youngwon22
Sep 10, 2003 06:33 PM
