2 channel or mono amp
Old Mar 17, 2007 | 10:03 AM
deeweezy187's Avatar
Default 2 channel or mono amp
I am think about what am i want to run my subs i have 2 12 inch kenwoods like these
http://www.onlinecarstereo.com...17651
The only problem is that i am stuck on with type of amp to run them I was looking at these
http://www.onlinecarstereo.com...14933
or
http://www.onlinecarstereo.com...17790
I need you audio guys to help.
Old Mar 17, 2007 | 10:57 AM
rcurley55's Avatar
New User
assuming your subs are the same as those in the first link, you need an amp that is stable at 2 ohm mono - the first amp can do that (850W), the second can not.
Old Mar 17, 2007 | 01:33 PM
Default Re: (rcurley55)
thank you
Old Mar 19, 2007 | 06:20 PM
skingfreak's Avatar
Default Re: (deeweezy187)
first amp FTW
Old Mar 22, 2007 | 09:51 PM
ARMED's Avatar
get the mono amp, and parallel the subs...youre good
Old Mar 23, 2007 | 06:13 AM
jz98ctr's Avatar
either amp will get the job done...although the bigger one might be a little bit overkill....it will however give you a little more dynamic headroom.
Old Mar 24, 2007 | 03:08 PM
Default Re: (jz98ctr)
thanks guys.
ChiLS
Audio / Security / Video
Feb 21, 2009 10:16 AM
VietFoo
Dec 25, 2005 12:03 AM
Orpheus1985
Jul 21, 2005 07:15 AM
hAtChXcElR8tion
Jul 27, 2004 06:44 AM
kbplaya
Feb 24, 2004 08:43 PM
