Which sub of these 2?
Old Feb 22, 2004 | 03:41 PM
kbplaya's Avatar
Default Which sub of these 2?
Well I will have about 350wrms to play with here, and it will be in a sealed enclosure in the back of my 95 integra (hatchback). So which of the following 2 subs do you recommend?
1) Alpine 12" dual 2 ohm Type R (4ohm mono)
2) JL Audio 12" W3V2 dual 2 ohm
Please state your reasons
thanks guys
-kb
Old Feb 22, 2004 | 04:29 PM
snoochtodanooch's Avatar
Default Re: Which sub of these 2? (kbplaya)
what impedance is your amp stable too, sounds like alpine amp maybe? regardless, i would get the W3. My questioning of what the amp is stable to is because you have two Dvc 2ohm subs listed, meaning either you want to go to 4 or 1 ohm. most likely i am guessing your amp is stable to 2 ohms, and in that case i would go with a dvc 4 ohm sub. but the amps minimum impedance is important.
Old Feb 22, 2004 | 07:17 PM
kbplaya's Avatar
Default Re: Which sub of these 2? (snoochtodanooch)
well its stable at 4ohm mono bridges but im gonna try it at 2
Old Feb 22, 2004 | 07:58 PM
turbod16y8's Avatar
the amp will run hot if u bridge it at 2 ohm. get the jl w3v2. very good sub. hit deep and loud and they can be wire to 4 ohm.
Old Feb 23, 2004 | 07:25 PM
Default Re: Which sub of these 2? (turbod16y8)
don't go to 2 ohms if your amp isn't rated for it.
Old Feb 23, 2004 | 09:30 PM
debogsr's Avatar
They are both awesome subs, but i stand by JL. No other company makes better subs. That W3 will slump hella hard.
Old Feb 24, 2004 | 04:27 PM
tegmech's Avatar
what amp are you running?
Old Feb 24, 2004 | 08:43 PM
Icey112's Avatar
Ive always was a jl fan but one of boys has the type r it slams and its not too much money i guess it just on how much you what to spend and what your going to run.
mmajedi
Audio / Security / Video
Nov 5, 2007 08:45 AM
89hbcivicguy
Mar 3, 2005 09:12 AM
