Fully built high compression block good with turbo? Already searched for it....
Hey there guys! I got a heck of a deal on a 2.0 GSR block that has a spun bearing. The guy can have the bearing replaced or I can get it like it is. He has 11.2:1 Arias pistons on Darton sleeves. My question is, do you guys think it's ok to run 10 PSI on that block? Or should I go ahead and swap out the pistons for a low compression setup to be safe. They did away with 93 octane in my area so all I got to work with now is 91.
I currently run a Greddy setup with the blue box on my EM1 with a semi-built B16A2. I already searched and most of the threads are about stock blocks so I thought you guys could shine some wisdom on this since it's a built block. Thanks in advance and any info would be great!
Modified by Boosted_MRCSI at 4:18 PM 3/17/2007
Plenty people have run turbos on stock ITRs, so that is not a issue.
However, a spun bearing is bad news. If you gotta fix a bearing then you may as well do a re-build. Also, I would get a new crank.
It really depends on which bearing was spun. If he spun a rod bearing, then you will need to replace the rod and crank. If it was a main bearing then the block is junk.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Muckman »</TD></TR><TR><TD CLASS="quote">If he spun a rod bearing, then you will need to replace the rod and crank. If it was a main bearing then the block is junk.</TD></TR></TABLE>
Yeap
Yeap
So should I even get it then? I have a spare B16A2 block that I can send out to get sleeved and everything so should I head that route? He said that the bearing that spun was at the #3 cylinder...
And the block was actually still running when he had it in his car. I guess the bearing was in the process of going bad. What should I do?
So if I'm reading this correctly, boost with high compression is fairly safe? I'm about to boost a GSR motor with CTR pistons.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by donm3ga »</TD></TR><TR><TD CLASS="quote">So if I'm reading this correctly, boost with high compression is fairly safe? I'm about to boost a GSR motor with CTR pistons.</TD></TR></TABLE>
all in the tune.
all in the tune.
Yeah, it's all in the tune. I'm gonna pass on that block. I'll just send out my b16a2 block and stroke it to a 1.7/8 and call it a day. Thanks for all the info guys.
the0ne
Jun 12, 2011 05:16 AM
