tranny problems help!!!!!!!!!!!!!!!!!!!!!!!!!!!! and it has
Old Mar 16, 2007 | 01:52 PM
efking1985's Avatar
Default tranny problems help!!!!!!!!!!!!!!!!!!!!!!!!!!!! and it has
ok i have a d16z6 in my hatch and im using a dx tranny. i just put a act stage 2 clutch now the problem is that when im in high rpm and try to quick shift in to 2nd gear it grinds i dont know why its doing this can any help me?
thanks in advance
Old Mar 16, 2007 | 02:07 PM
sanimalp's Avatar
$cat /dev/urandom
Default Re: tranny problems help!!!!!!!!!!!!!!!!!!!!!!!!!!!! and it has (efking1985)
it is because your syncro's dont have time to do their job with your "quick shift". your syncro's are probably worn out as well. shift slower and you probably wont have that problem.
A clutch upgrade doesnt allow you to shift faster. it allows your engine to transmit power to the transmission more efficiently without slipping.
Old Mar 16, 2007 | 02:50 PM
dr_latino999's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by efking1985 &raquo;</TD></TR><TR><TD CLASS="quote">ok i have a d16z6 in my hatch and im using a dx tranny. i just put a act stage 2 clutch now the problem is that when im in high rpm and try to quick shift in to 2nd gear it grinds i dont know why its doing this can any help me?
thanks in advance</TD></TR></TABLE> You have a no name short shifter I'm assuming, and your stock transmission is now getting very pissy at you.
Old Mar 16, 2007 | 02:53 PM
RACINTWEEK's Avatar
Default Re: tranny problems help!!!!!!!!!!!!!!!!!!!!!!!!!!!! and it has (dr_latino999)
try poly shifter bushings and a stock shifter. if it continues to grind use Synchromesh to cover it up untill you can get a good Si or ZC trans
Old Mar 16, 2007 | 03:05 PM
Default Re: tranny problems help!!!!!!!!!!!!!!!!!!!!!!!!!!!! and it has (RACINTWEEK)
^ The good old patch up the mechanics without patching up the driver
Old Mar 16, 2007 | 03:15 PM
RACINTWEEK's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by dr_latino999 &raquo;</TD></TR><TR><TD CLASS="quote">^ The good old patch up the mechanics without patching up the driver</TD></TR></TABLE>
do you really think he'll stop "quick shiftin"???
he might as well try to make his car last
Old Mar 16, 2007 | 03:57 PM
efking1985's Avatar
what is Synchromesh ?
Old Mar 16, 2007 | 04:37 PM
Heylookits shawn's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by efking1985 &raquo;</TD></TR><TR><TD CLASS="quote">what is Synchromesh ?</TD></TR></TABLE>
pimp juice in a bottle.
not really, just a synthetic trans fluid, made by GM. SUPPOSEDLY it prevents grinding, but ive always used oem honda fluid and it works fine for me.
Old Mar 16, 2007 | 04:45 PM
efking1985's Avatar
Default Re: tranny problems help!!!!!!!!!!!!!!!!!!!!!!!!!!!! and it has (Heylookits shawn)
does anyone have a link or a site where i can find a diy to change tranny fluid?
Old Mar 16, 2007 | 04:56 PM
dbiker207's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by efking1985 &raquo;</TD></TR><TR><TD CLASS="quote">does anyone have a link or a site where i can find a diy to change tranny fluid?</TD></TR></TABLE>
no link, but its easy as hell. just look near the passenger axle on the transmission, there should be a 17mm bolt and a bolt with a 3/8 ratchet hole in it. the 3/8 ratchet bolt is the drain and the 17mm is the fill hole. drain then put the plug back. then take out the 17mm and use a piece of 1/2 inch hose about 2-3 feet long and a funnel to fill it until its level with the bottom of the fill hole. replace the fill plug and your done
i love all these ppl that think the brand of a short shifter makes a difference. the reason that short shifters "eat" syncros is the spin down time of the countershaft. from a engineering point of veiw, the shifer (short or long throw) will still fully engage the syncro. so a 5 million dollar b&m shifter is no better than a 5 dollar eGay shifter
Old Mar 16, 2007 | 08:51 PM
brandoom's Avatar
An Hero
Default Re: tranny problems help!!!!!!!!!!!!!!!!!!!!!!!!!!!! and it has (dbiker207)
Here ya go buddy. Its for a sohc but i think its the same ****. https://honda-tech.com/zerothread?id=1184914
Old Mar 17, 2007 | 01:00 PM
RACINTWEEK's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Heylookits shawn &raquo;</TD></TR><TR><TD CLASS="quote">
not really, just a synthetic trans fluid, made by GM. SUPPOSEDLY it prevents grinding, but ive always used oem honda fluid and it works fine for me. </TD></TR></TABLE>
it doesnt prevent it, just covers it up
jayhwk75
10
Aug 22, 2005 02:29 PM
5 Skware
Apr 13, 2005 05:04 AM
93SIRII
13
Oct 6, 2003 10:12 PM
