IS IT TRUE???
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by egb16pg »</TD></TR><TR><TD CLASS="quote">B16a's dont use a knock sensor?
oh and also can you use a d16z6 obd1 vtec distributer on a b16a?
Modified by egb16pg at 11:54 AM 3/16/2007</TD></TR></TABLE>mine dosnt use one,but for some reson the p30 ecu i was useing looked for it and thru a code.i put in a chiped p28 an its fine now.you just need to tune the knock sensor out of you ecu if you getting a code.
i dont know about the distributer
I believe the older ones dont use KS but the newer ones 99-00 do. For the Del Sol version i have no clue weither they do or not.
For the dist. you could use the internals in the B16 case or ghetto it by cutting off the legs or something.
Are you running an OBD O, 1, or 2 ECU?
you need a VTEC dizzy for your b16. Either a GSR ,Hype-R or B16. An LS will work if you cut off on of the mounting flanges but have been known to not run well.
just makes sure that if it's an OBDO ecu you use an OBDO dizzy (b16 will be your only choice)
If it's an OBD I or II ECU you are using you can use either a OBD I or II dizzy, Youll just need to get the corosponding plugs re-pin the plugs on the dizzy to make it work with what ever application your using
A D series can be mounted using 1 bolt hole but your timing will be way off.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Luserkid »</TD></TR><TR><TD CLASS="quote">I believe the older ones dont use KS but the newer ones 99-00 do. For the Del Sol version i have no clue weither they do or not.
For the dist. you could use the internals in the B16 case or ghetto it by cutting off the legs or something. </TD></TR></TABLE>
not necessary true. maybe the first gen of b16 (obd 0) don't have them, but i have a 94 out of an eg6 (which is a obd 1) and it has a knock sensor.
for B16 ECUs (generally speaking, there are a couple exceptions)
obd0 - no knock sensor present
obd1 - knock sensor present
obd2 - knock sensor present
the engine doesn't care if it has a knock sensor, only the ECU matters.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by egb16pg »</TD></TR><TR><TD CLASS="quote">oright thanks everyone..
im running a obd1 ecu</TD></TR></TABLE>
then get an OBD I or OBD II DOHC VTEC dizzy and be done with it.
