Can you stroke a B18c5?
Old Mar 16, 2007 | 03:53 AM
LDS's Avatar
LDS
Default Can you stroke a B18c5?
Hey guys Im looking at some of eagles Engine packages and my friend who runs a performance shop game me a killer price on one of there assymblies but before I buy I need some one with experiance answer me a few questions I have.
By the way my wifes car is a 2000 integra type r (currently apart)
myquestions are:
Can you stroke the stock B18c5 block?
Is 82mm the biggest bore I can go with out sleeving?
Head is skunk pro2s and supporting valvetrain including valves from skunk.
Whats the most extreme I can go with this block and still drive it on the street?(im prepared to have to run 110 or 100 octane if need be)
We want to run 12s on motor. I did alot of of searching lastnight but no one was keeping there b18c5 block. My wife insist on keeping that block so getting an ls vtec or b20 block is out of the question. Who on here is running 12 in there type r that can give me some pointers? Theres one guy on here running 12.2 at like 113 on motor in his type r but i couldent find him.
I have the money and time to do this. but remeber im trying to stay away from sleeving I know that sounds weired. thanks.
Old Mar 16, 2007 | 10:50 AM
Agnom's Avatar
Default Re: Can you stroke a B18c5? (LDS)
LS crank and rods is the cheapest way to go for 89mm stroke
Old Mar 16, 2007 | 01:07 PM
spun Vtec's Avatar
in on this..
Old Mar 16, 2007 | 04:51 PM
j spec's Avatar
Default Re: Can you stroke a B18c5? (spun Vtec)
Keep the block buy an ls crank, some ls rods, arp rod bolts, and some P30 pistons. With the right boltons it should be a 12sec car; if car isn't too heavy.
Old Mar 17, 2007 | 04:00 PM
LDS's Avatar
LDS
This is sounding promising. I have a friend who is selling his b20 crank,I dont know what brond long stroke rods, 85mm 14.1 pistons. I thinking about round his stuff up depending on how my reaserch goes.
I know you guys are saying ls rods and crank but what about b20 stuff, will they fit?
Old Mar 17, 2007 | 04:14 PM
doood's Avatar
been there done that
Default Re: (LDS)
ls and b20 rods and crank are the same. why are you opposed to sleeving and not stroking?
Old Mar 17, 2007 | 04:55 PM
LDS's Avatar
LDS
doood- We decited to go ahead and sleeve to 85mm (golden eagle).
Anybody know the price on that? I went to the website but no price.
Old Mar 17, 2007 | 04:56 PM
doood's Avatar
Default Re: (LDS)
camp1320 has the best prices on golden eagle sleeving
Old Mar 19, 2007 | 06:01 AM
civicandy's Avatar
Default Re: (doood)
anybody know if you have to remove the piston squirters on the b18c's if you stroke them? any downfall to removing them?
Old Mar 19, 2007 | 07:54 AM
spun Vtec's Avatar
Default Re: (civicandy)
Or you could just try to find the JDM 2.0L B18C5 like in doood's sig
Old Mar 19, 2007 | 08:50 AM
civicandy's Avatar
Default Re: (spun Vtec)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by spun Vtec &raquo;</TD></TR><TR><TD CLASS="quote">Or you could just try to find the JDM 2.0L B18C5 like in doood's sig
LOL. I've been looking, have had zero luck. lol That ranks up there with the "stage 3 vtec solenoid" I've heard about.
But really...is it a good idea to not use the piston squirters? every stroker kit says you have to remove them (for a b18c)
Old Mar 19, 2007 | 12:45 PM
doood's Avatar
the squirters arent really needed when running forged internals. take them out and plug the holes.
Old Mar 19, 2007 | 01:19 PM
pythoner's Avatar
EDIT: reading owns me
Old Mar 20, 2007 | 06:56 AM
civicandy's Avatar
Default Re: (pythoner)
What is the stock compression ratio for the ITR, usdm and jdm?
Old Mar 20, 2007 | 08:46 AM
00Red_SiR's Avatar
All Motor Mentor
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by civicandy &raquo;</TD></TR><TR><TD CLASS="quote">What is the stock compression ratio for the ITR, usdm and jdm? </TD></TR></TABLE>
USDM = 10.6:1
JDM = 11.1:1
Old Mar 20, 2007 | 08:48 AM
civicandy's Avatar
Default Re: (00Red_SiR)
Thanks. What does your motor put down for hp, minus the nitrous?
Old Mar 20, 2007 | 09:10 AM
00Red_SiR's Avatar
All Motor Mentor
I'll let you know once I find out in a few weeks time. I'm just finishing puting everything together now and once completed, I will be tuning everything.
The main thing I changed from my old setup was my stock B16a short block for a new b18c5 short block from Acura as well as cams ( I ran S2S1's on my B16). My old setup made 160hp and 111TQ all motor and 231hp 170 Tq on nitrous (75 hp shot).
My new setup should be a solid performer.
Old Mar 20, 2007 | 09:26 AM
DA_JDM's Avatar
Stay 1.8L Try to make power out of it
Old Mar 20, 2007 | 09:52 AM
civicandy's Avatar
Default Re: (DA_JDM)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by DA_JDM &raquo;</TD></TR><TR><TD CLASS="quote">Stay 1.8L Try to make power out of it </TD></TR></TABLE>
I'm on this fence. Is there really any advantage to going to 2.0L? I wonder how much more hp and tq. that really makes, compared to the cost. I want to have solid 200whp numbers. I'm thinking a gsr block, jdm itr pistons, b16 head and 2 layer headgasket will yeild that, along with a good valvetrain, cams and header
Old Mar 20, 2007 | 04:41 PM
alterdcreations's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 00Red_SiR &raquo;</TD></TR><TR><TD CLASS="quote">I'll let you know once I find out in a few weeks time. I'm just finishing puting everything together now and once completed, I will be tuning everything.
My new setup should be a solid performer.</TD></TR></TABLE>
danm that nitrous made that b16 scream
Old Mar 20, 2007 | 07:38 PM
00Red_SiR's Avatar
All Motor Mentor
Default Re: (alterdcreations)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by alterdcreations &raquo;</TD></TR><TR><TD CLASS="quote">
danm that nitrous made that b16 scream</TD></TR></TABLE>
It did! That's what I like about nitrous the most, it's there if you really need it and when you don't you have a very reliable and quick daily driver. Perfect compromise for me.
logg_frogg
Feb 11, 2008 10:38 AM
drift_n_shift
Jul 28, 2006 09:09 PM
iiilgsrlll
Sep 12, 2003 03:43 PM
EF_LSVtec
May 31, 2002 12:00 PM
