FS: T3/T4oe 57Trim .63 a/r
I'm selling my T3/T4oe 57Trim .63 a/r. There is 0 shaft play and there are no broken seals. Turbo was on my stock block gsr turbo and spooled beautifully.
Turbo has a stage 3 wheel with a Garret compressor housing and a under 6month old precision 5-bolt exhaust housing. I will also throw in the original 4-bolt garret exhaust housing. The 4-bolt housing does have a broken bolt in it, but can easily be taken out, no need to re-tap it.
Pics will be up shortly. Turbo is rated @ 440hp.
I'm asking $350 + shipping.
PM's replied.
Yes real garret aside from the 5-bolt new Precision exhaust housing. The whole turbo is from garret, I just replaced the exhaust housing because 5-bolt manifold/downpipe setups are compatible with a/c. The garret 4-bolt housing will be included as well.
If you dont have your downpipe-manifold setup already and are unsure if you are going 5-bolt or 4-bolt this is the perfect deal for you!
JoePSI
Oct 25, 2007 12:03 PM
Metal Head
Jul 11, 2006 02:38 PM
TheIntegraGuy
Aug 9, 2005 11:00 AM
