EBAY 60MM WASTEGATE whos useing one ???????
Old Mar 15, 2007 | 06:59 PM
t57b18's Avatar
Default EBAY 60MM WASTEGATE whos useing one hks knock off ???????
i iknow theres some one on this board useing one hows it work..
Old Mar 15, 2007 | 07:04 PM
almostboostedgsr's Avatar
Default Re: EBAY 60MM WASTEGATE whos useing one hks knock off ??????? (t57b18)
why buy ebay?. Its a blown motor waiting to happen. Buy reilable parts like a tial, or a real hks, .
Im not trying to say ebay is bad, but for a wastegate I would trust a name brand.
Old Mar 15, 2007 | 07:13 PM
spoolin_teg's Avatar
not saying ebay stuff is great, but everyone of my friends using their stuff loves it. My friends got a 1g tsi with just a ebay t3/t4, a tial knock off, a ebay ,manifold and 20 psi, and the cars runs low 11's. J rod built it for those who know him. There's also a DSM guy running 9's last I knew with all ebay stuff. idk
Old Mar 15, 2007 | 07:24 PM
91tegrals's Avatar
wit ebay stuff its hit or miss back in the day peolpe were having lots of probs with knock offs now it seems there stuff is getting a lott better...
Old Mar 15, 2007 | 07:26 PM
Boostedb20EH2's Avatar
Default Re: (91tegrals)
No one has responded because they are currently in their garages fixing their blown up cars
Old Mar 15, 2007 | 07:27 PM
1baddturbosi's Avatar
Default Re: EBAY 60MM WASTEGATE whos useing one hks knock off ??????? (spoolin_teg)
well... i gotta knock-off tial wastegate. make sure u put the firing ring on. but anyway, its fine and i havent had a problem with it. but my aem ems has a fuel cut-off as a back up just in-case it acts up, but so far so good. But if i had the $, a tial wastegate is what i would own.
Old Mar 15, 2007 | 07:38 PM
t57b18's Avatar
Default Re: EBAY 60MM WASTEGATE whos useing one hks knock off ??????? (1baddturbosi)
im looking for someone useing a hks knock off 60mm big gate ..i know if you going to spnd the money buy it once and not again but a true hks 60 is 899.99 or so just asking if theres any one useing it ..
Old Mar 15, 2007 | 07:40 PM
CivicVX94's Avatar
how much power do you plan on making to justify the use of such large of a wg?
or do you just plan to run ultra low boost on a small turbo for dd and think you need a 60mm wg to get the job done?
Old Mar 15, 2007 | 07:42 PM
Default Re: EBAY 60MM WASTEGATE whos useing one hks knock off ??????? (CivicVX94)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by CivicVX94 &raquo;</TD></TR><TR><TD CLASS="quote">how much power do you plan on making to justify the use of such large of a wg?
or do you just plan to run ultra low boost on a small turbo for dd and think you need a 60mm wg to get the job done?</TD></TR></TABLE>
Ebay is the place to trust for high boost applications!
Old Mar 15, 2007 | 07:44 PM
Default Re: EBAY 60MM WASTEGATE whos useing one hks knock off ??????? (Boostedb20EH2)
u should get a 38mm wg to start!!!
Old Mar 15, 2007 | 07:46 PM
CivicVX94's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Boostedb20EH2 &raquo;</TD></TR><TR><TD CLASS="quote">
Ebay is the place to trust for high boost applications!</TD></TR></TABLE>
Ebay FTW
lmao..
Old Mar 15, 2007 | 07:56 PM
t57b18's Avatar
did i say anything about buying one ... no im asking if there any one who has used one and i have a try tial 38mm gate on my car. i was looking around on ebay and this was in a listing so i thought i would see f theres anyone one here using it ..and buy the way im shure theres someone running this gate one hatertech !
Old Mar 15, 2007 | 08:20 PM
jdmef-9's Avatar
if theres one thing you should not be a cheap *** about its a waste gate! just buy a damn tial!!!!!!!!
Old Mar 15, 2007 | 10:23 PM
speedlabx2005's Avatar
Default Re: (jdmef-9)
i'm running a 60mm off my neukin ramhorn but i'm still getting boost creep issues my turbo size t3t67HO holds boost good to 8200RPM then after that it creeps about 4psi more than i want. i want to keep my boost around 9psi on pump gas. i'm getting less creep than with the 44mm but i think its because my turbo is too large. other than that if i change springs to the medium one, it holds boost 15psi rock solid.
Old Mar 15, 2007 | 10:57 PM
jdmsiR20's Avatar
Default Re: (speedlabx2005)
why not a blox? i've seen them go for $100
Old Mar 15, 2007 | 11:44 PM
zexxbo's Avatar
Default Re: (jdmsiR20)
https://honda-tech.com/zerothread?id=1891036
Old Mar 16, 2007 | 01:09 AM
90dxhmt's Avatar
Default Re: (zeimbo)
They work pretty good along with the rest of the SSauto gates.Just double check the diaphram is seated correctly etc.I have used many without problem.
Old Mar 16, 2007 | 06:51 AM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by t57b18 &raquo;</TD></TR><TR><TD CLASS="quote">and buy the way im shure theres someone running this gate one hatertech !</TD></TR></TABLE>
No one is hating, you asked an a question. We gave you an opinion..and you dont happen to like our opinions
Old Mar 16, 2007 | 07:04 AM
t57b18's Avatar
anyone that is useing this gate got pics of it on the car ..
Old Mar 16, 2007 | 07:19 AM
CivicVX94's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by speedlabx2005 &raquo;</TD></TR><TR><TD CLASS="quote">i'm running a 60mm off my neukin ramhorn but i'm still getting boost creep issues my turbo size t3t67HO holds boost good to 8200RPM then after that it creeps about 4psi more than i want. i want to keep my boost around 9psi on pump gas. i'm getting less creep than with the 44mm but i think its because my turbo is too large. other than that if i change springs to the medium one, it holds boost 15psi rock solid.</TD></TR></TABLE>
boost creep occurs in most cases from poor wastegate placement.
it would not creep b/c you have a large wg and large turbo, think about it, the physics aren't there. It could spike w/ a small wg and a large turbo and attempting to run low boost, but everything is relative to the engine and the entire setup and it's hard to generalize how it can happen. proper wg size/turbo sizing/wg placement are key.
either way, boost creep/spike/whatever name you have for it, is caused attempting to run too little boost on a setup where it causes a "back up" of exhaust gases. the wg is flowing allll the exhaust it can flow w/ whatever spring you have in it and the turbo is spinning faster and faster the higher you rev. WELL, b/c you're producing mroe and more exhaust gas the higher you rev, it has to have somewhere to go. if the wg can't flow anymore, it has to go through the turbo, which will cause you to boost more than the desired amount.
Old Mar 16, 2007 | 09:03 AM
DSMu4ia's Avatar
When did that car ever run 11's with the current owner?
Old Mar 17, 2007 | 07:55 AM
Default Re: EBAY 60MM WASTEGATE whos useing one hks knock off ??????? (DSMu4ia)
hasn't yet, last time I looked outside it was snowing. AWD's good, but not that good
Old Mar 17, 2007 | 08:13 AM
awdgsx96's Avatar
I like seeing more and more DSMers on here. It's nice to bond with others Lol.
But, to 1baddturbosi, when you say you have AEMS, and you can't afford a TiAl, where did the money go? The management? Haha
Old Mar 19, 2007 | 01:22 PM
litovi3tboi503's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by t57b18 &raquo;</TD></TR><TR><TD CLASS="quote">im looking for someone useing a hks knock off 60mm big gate ..i know if you going to spnd the money buy it once and not again but a true hks 60 is 899.99 or so just asking if theres any one useing it ..</TD></TR></TABLE>
No man! why get 60mm knock off? might as well get a 90mm knock off
Old Mar 19, 2007 | 07:52 PM
Default Re: EBAY 60MM WASTEGATE whos useing one hks knock off ??????? (awdgsx96)
lol.... no, i bought my aem ems used on ebay shipped for $650. i bought the wg know 1/4 of what i know about turbos now. If i could do it over, i woulda just bought a tial wg and be done.
bzyq2001
Feb 10, 2011 04:20 AM
wantboost
Jul 8, 2010 05:47 PM
abaaj
Feb 9, 2005 03:56 PM
ghettochild
Sep 23, 2004 07:37 PM
