Purge cut-off solenoid valve not connected
Old Mar 15, 2007 | 06:27 PM
hondacivic90zc's Avatar
Default Purge cut-off solenoid valve not connected
i noticed that my purge cut-off solenoid valve is not connected and i think it is because the guy who did the mpfi swap on my 88 crx dx couldnt find the wires for it because they had already been cut off of the si harness i got for the swap. He must of just thought that the purge solenoid was not needed. I found the wires, they were in the wire loom with the map sensor wires.
Does anybody know what it does and if anything, what could it affect if it was not connected?
My car throws a code for o2 every once in awhile and could this be caused by the purge solenoid?
Old Mar 15, 2007 | 08:32 PM
racin_jayson's Avatar
Default Re: Purge cut-off solenoid valve not connected (iandavis90)
purge solenoid is unrelated to O2, it is for releasing vapors from your charcoal canister and is pretty unimportant, your o2 code might be due to backwards wiring or a bad sensor.
hope that helped
Dee_333
Jul 7, 2011 07:22 PM
98exturd
Aug 12, 2007 02:31 PM
pheen0m
Feb 25, 2005 07:29 PM
bOOsTiNSoHcVtEc
Jun 6, 2003 09:30 PM
senpai
Jan 12, 2003 01:24 PM
