Fill up time
For some reason whenever i fill my tank up with gas and get in it never wants to start, like its not getting gas then ill rev it and if i let it idle it will die almost immeditly. Any one know whats wrong
Are you over filling the tank? It is possible to over fill the gas tank. When you fill up with gas do you stop when the pump shuts the nozzle off, or do you continue to fill the car with gas just to top it off.
If you over fill the tank sometimes the excess gas will flow back through the EGR system which can cause a similar problem to which you have.
mrspeedy69
Apr 15, 2009 06:11 AM
