B18 with B16 head or B20 reg. for my 92 civic
Old Mar 15, 2007 | 12:55 PM
91EF919's Avatar
Default B18 with B16 head or B20 reg. for my 92 civic
i have an 92 civic hatch it has a ls integra motor in it right now so should i just do ls/vtec or get a b20 a reg. one with a stock head?
Old Mar 15, 2007 | 01:07 PM
ek4h's Avatar
Default Re: B18 with B16 head or B20 reg. for my 92 civic (ILoveMyHonda919)
if you want more power ls/vtec cause b20 just just like having a ls
so poor mans type r is the way to go
Old Mar 15, 2007 | 01:59 PM
bbbleondacomeup's Avatar
if u have that option y not go b20/vtec? its faster then both of them
Old Mar 15, 2007 | 02:16 PM
91EF919's Avatar
Default Re: B18 with B16 head or B20 reg. for my 92 civic (bbbleondacomeup)
how much will that cost + labor for the b20 vtec where does the b20 come from a crv
Old Mar 15, 2007 | 02:18 PM
Nongan's Avatar
i got a quote for an ls/vtec from a GOOD shop for around $4k installed. wouldn't imagine a crvtec to be much more. may even be less.
Old Mar 15, 2007 | 02:25 PM
Jay_Sensing's Avatar
Default Re: B18 with B16 head or B20 reg. for my 92 civic (Nongan)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Nongan &raquo;</TD></TR><TR><TD CLASS="quote">i got a quote for an ls/vtec from a GOOD shop for around $4k installed. wouldn't imagine a crvtec to be much more. may even be less.</TD></TR></TABLE>
That is far beyond ridiculous. I don't care what the shop is or how "good" they are, 4k is insane unless it comes with a built head and lsd plus forged internals.
You already have the LS, buy the vtec head, a good conversion kit, and have at it. While you are at it, if you want more power, yank the bottom end too and have some B16 pistons put on the LS rods for more compression and make a bit more power. Either way, a B20 is a nice little setup to start out with but no point in buying one when you already have an LS.
Old Mar 15, 2007 | 02:33 PM
91EF919's Avatar
Default Re: B18 with B16 head or B20 reg. for my 92 civic (Jay_Sensing)
thats alto 4k my cuz got his for 2k and it works perfectly i might go ls vtec then work on the bottom end of it
Old Mar 15, 2007 | 02:36 PM
Nongan's Avatar
ok, let me rephrase what i said. i got a quote for a ls/vtec with b16 pistons, arp rod bolts/headstuds, new timing belt, water pump, a vtec oil pump, and a b16 tranny. i don't think its unreasonable because of the amount of time to build it.
edit: forgot to mention a 6-puck act clutch and flywheel.
Old Mar 15, 2007 | 02:50 PM
if i were u i would def just build the ls/vtec cause u already have the ls..... but get all the parts urself and then just bring it the shop to build.... im gathering all the parts for mine which total about $1600 plus about another 500-600 for labor and that included aftermarket piston and rods.. but not including water pump and belt so u can add that it
Old Mar 15, 2007 | 03:32 PM
91EF919's Avatar
k thats sounds better i had a integra with ls/vtec but i crashed it so i just bought a civic hatch my integra was runnin mid 13's will my civic will be faster if i build it up
Old Mar 15, 2007 | 04:50 PM
doood's Avatar
been there done that
boost that bitch
Old Mar 15, 2007 | 05:06 PM
Darknessezz's Avatar
im runnin a del sol B20 vtec b16 head. Crazy torque!! Compared to my old setup ls/v. But i'd still go with the ls for now until it blows.
Old Mar 15, 2007 | 05:14 PM
fmrprojects's Avatar
Default Re: B18 with B16 head or B20 reg. for my 92 civic (Darknessezz)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Darknessezz &raquo;</TD></TR><TR><TD CLASS="quote">im runnin a del sol B20 vtec b16 head. Crazy torque!! Compared to my old setup ls/v. But i'd still go with the ls for now until it blows.</TD></TR></TABLE>
yeah wait till it blows up in your face. my 1.8 ls vtec setup made 217hp and 139tq. i only put 4700 into it. but thats me building it outta my garage. my old b20 vtec made 180hp and 138 tq stock block and stock head. lasted me 6 months and blew up from reod bolt stretch.
so if you gonna build any motor build up the bottom end with some oem or rs oem style pistons with some arp rod bolts and it should be fine
Old Mar 15, 2007 | 05:34 PM
91EF919's Avatar
Default Re: B18 with B16 head or B20 reg. for my 92 civic (fmrprojects)
who do u think ill run if i do ls/v n bolt ons cuz i gotta race set up n i got money on the line and i need 2 do someting fast n kinda cheap
srt dub-R
Nov 6, 2007 10:51 AM
90scrx
Dec 8, 2004 12:28 PM
lopezvic03
Jun 23, 2004 12:24 PM
92SiHatchie
36
May 28, 2003 11:47 AM
Sassafrass
Jan 5, 2003 10:11 PM
