can you reuse a headgasket?
Old Mar 14, 2007 | 06:36 PM
luvs2spooge's Avatar
Default can you reuse a headgasket?
was just wondering if you can reuse a headgasket? my buddy has a turbo greddy headgasket that he's gonna let me use but he used it already on his sohc.
would it be safe to use it?
and would a z6 one work/fit on a y8? thanks
Old Mar 14, 2007 | 06:42 PM
BJOnewiper's Avatar
Yes and yes.
Old Mar 14, 2007 | 06:43 PM
melovesboost's Avatar
it is not recommended to reuse Headgasket.
Mykizism's Avatar
what?? ive never heard of re-using head gaskets
Old Mar 14, 2007 | 07:31 PM
Default Re: can you reuse a headgasket? (luvs2spooge)
what would i have to do to reuse it? just slap it on?
Old Mar 14, 2007 | 07:32 PM
like i said before its not recommended to reuse a headgasket.. i garuntee you that you will be changing it again very shortly afterwards
Old Mar 14, 2007 | 07:35 PM
Boilermaker1's Avatar
Its like 30 bucks for a new one from honda... thats pretty cheap insurance. Why even think about reusing it?
Old Mar 14, 2007 | 07:42 PM
Default Re: (Boilermaker1)
its a greddy turbo headgasket guyz costs 250.. its reeally thick.. for turbo setups
Old Mar 14, 2007 | 07:43 PM
Dunc's Avatar
BCICAN
Reusing a headgasket is like changing your oil but putting whatever you drain out back into the motor. It flat out stupid to do...end of story. A big to who ever is dumb enough to reuse headgaskets.
Old Mar 14, 2007 | 08:53 PM
kobokie's Avatar
Would you reuse a condom !!!!!!!!!!!
Old Mar 14, 2007 | 09:14 PM
Default Re: can you reuse a headgasket? (kobokie)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by kobokie &raquo;</TD></TR><TR><TD CLASS="quote">Would you reuse a condom !!!!!!!!!!!</TD></TR></TABLE>
HAHAHA i was just waiting for this comment.
Old Mar 15, 2007 | 04:52 AM
PrecisionH23a's Avatar
Yea... just turn it inside out.
Don't re-use the HG... especially on a boosted application.
Old Mar 15, 2007 | 05:23 AM
99B16Si's Avatar
Default Re: can you reuse a headgasket? (PrecisionH23a)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by PrecisionH23a &raquo;</TD></TR><TR><TD CLASS="quote">
Don't re-use the HG... especially on a boosted application.</TD></TR></TABLE>
lol
i have re-used them before with no issues......both headgaskets and condoms that is
Old Mar 15, 2007 | 02:57 PM
2slo4me's Avatar
Default Re: (Dunc)
"its a greddy turbo headgasket guyz costs 250.. its reeally thick.. for turbo setups"
if all ya dicks would actually read its a turbo headgasket more like a spacer so yes u can reuse it....
Old Mar 15, 2007 | 02:59 PM
bnut510's Avatar
no. u wash it out, hang dry, then relubricate with favorite lubricant
Old Mar 15, 2007 | 03:25 PM
BoostedEG6's Avatar
Default Re: (2slo4me)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 2slo4me &raquo;</TD></TR><TR><TD CLASS="quote">if all ya dicks would actually read its a turbo headgasket more like a spacer so yes u can reuse it....</TD></TR></TABLE>
No its a headgasket.... not a spacer... all it is, is a thick HEADGASKET
to the OP just go get a factory headgasket.... all the one your friend has is lower the compression.... basically a band-aid for boost... just get a new one and get it tuned right an you wont have to worry about it
Old Mar 15, 2007 | 04:06 PM
yee SERIOUS's Avatar
Default Re: can you reuse a headgasket? (99B16Si)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 99B16Si &raquo;</TD></TR><TR><TD CLASS="quote">i have re-used them before with no issues......both headgaskets and condoms that is</TD></TR></TABLE>
that's sig material right there. hahaha. "reusing headgaskets are like reusing condoms"...remember that
Old Mar 15, 2007 | 04:56 PM
doood's Avatar
been there done that
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 2slo4me &raquo;</TD></TR><TR><TD CLASS="quote">"its a greddy turbo headgasket guyz costs 250.. its reeally thick.. for turbo setups"
who's the dick, the ones telling him to not reuse it, or the one giving bad info?
hint: you
Old Mar 15, 2007 | 05:00 PM
EK FLY's Avatar
Default Re: can you reuse a headgasket? (kidsafe yee)
well depends I seen a headgasket that u can reeuse the middle part wich is a different material , buy a new headgasket and split it apart and use the center pice of ur old headgasket
see the thing with oem headgasket is when u tight it down the head it will make the head gasket not usable when u remove ur head
Old Mar 15, 2007 | 06:53 PM
HiProfile's Avatar
Default Re: can you reuse a headgasket? (super-hatch)
Honda's are running OEM factory timing maps or 87 octane, so there's little reason to go below 9:1. The only reason would be for 400+ whp, and at that point, you don't want to be reusing headgaskets.
Copper gaskets are sometimes said to be reusable. MLS headgaskets have a special floro-polymer on them (the black stuff) that rips apart when you remove it. The ribbing on the stainless will still help seal, but not all that much. I got to ~11psi (in this case, ~220whp) before my reused HG would leak. I got the engine for almost nothing, so I didn't feel like putting anything into it. Anyways, OEM MLS gaskets work great and aren't all that expensive - $23.84 when you buy it from a certain dealership online.
Old Mar 15, 2007 | 08:03 PM
yaaj1320's Avatar
Default Re: can you reuse a headgasket? (HiProfile)
my theory is---
if the headgasket new and tourqed once and the motor has NEVER beeen started up....i think its fine to re-use...BUT i have never tried it....
Old Mar 16, 2007 | 04:13 AM
EK FLY's Avatar
Default Re: can you reuse a headgasket? (yaaj1320)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by yaaj1320 &raquo;</TD></TR><TR><TD CLASS="quote">my theory is---
if the headgasket new and tourqed once and the motor has NEVER beeen started up....i think its fine to re-use...BUT i have never tried it....</TD></TR></TABLE>
nope wrong
once u torque down the cylinder head the headgasket will be crush and u cant reeuse it anymore
Old Mar 16, 2007 | 04:37 AM
TheWickedOne's Avatar
Personally I like using new gaskets, I have reused a gasket a couple times. Depending on the situation - If the gasket was from a motor that overheated .. I'd toss it. If you feel the gasket is in decent shape, clean it up with some brake cleaner and spray a few coats of copper spray on it .. and you should be good to go. But nothing beats a brand new gasket.
Mak Valley
Dec 21, 2007 12:29 PM
honda_joe
Nov 27, 2003 05:44 PM
jung4g
Sep 8, 2003 04:52 PM
Todd00
Jun 17, 2002 03:55 PM
Carp
Feb 6, 2002 10:27 AM
