what gasket will fit on a TDO4H-15G Greddy Turbo
New User
I have a Greddy turbo, a TDO4H from a Greddy 92 to 95 civic turbo kit. I need to find a gasket to fit the turbo to Greddy turbo manifold.
is there any gaskets I can go get from a local parts store that will work on it, or who can I order one from
Thanks for any help
Craig
Thanks for any help
Craig
New User
Re: what gasket will fit on a TDO4H-15G Greddy Turbo (Carp)
yeah go to a Mitsu dealer and get the gasket from a turbo eclipse. i got mine there. I have the part number at home if you want to wait till 2nite.
New User
yep, the oil return is the same. I had to buy a whole oil return pipe from them and then I just cut it up.
New User
Re: what gasket will fit on a TDO4H-15G Greddy Turbo (Pritos)
if you have the part numbers could you give them to me, but if not you have been a great help!
Thanks
Thanks
New User
yah, I'll be sure to give you part numbers. I had them print out a diagram with all the part numbers of that turbo section.
drop me an email!
drop me an email!
Re: what gasket will fit on a TDO4H-15G Greddy Turbo (DRAGLS)
Yes listen to DRAGLS. I went to Mitsubishi when I needed a new exahust gasket between the turbo and manifold and Mitsu didn't have anything even remotley close. We checked the gaskets for the TD05 and T25, neither was close. Turned out that Nissan used the same gasket for the 300ZX TT
New User
Re: what gasket will fit on a TDO4H-15G Greddy Turbo (VTC_CiViC)
Seriously? I thought most of the smaller Mitsu turbo's shared the same bolt pattern. I had a t25, td04, and a td05 all side by side and they were all the same. from the mounting flange to the o2 housing.
anyway, my scanner is acting like shibbitz 2nite so I'll scan a cool part's diagram I got from my Mitsu dealer and post it in the morning.
New User
assuming the flanges are the same, I believe they are - others differ, here are the part numbers for a t25 in a dsm application. I just may be wrong and they ARE different. I dont think so though,
[Modified by Pritos, 10:55 AM 2/6/2002]
I dunno, maybe mine is a freak, but we compared the gasket's right there at the counter and they weren't remotley the same....
New User
strange, maybe you've got a freakazoid.
all 3 I've had were from dsm's. t25, td04hl, and td05h and all were the same. and I've reused the same gasket since the t25.
The exhaust flange on the Greddy TD04 is different than the DSM TD04. Just like how the HKS says that their exhaust manifolds will fit a T-25. Just not a DSM T-25. The HKS manifold happens to have the same flange as the Greddy turbo, however. Many people opt to bolt up the HKS B-series manifold to adapt the Civic Greddy kit instead of modifying the Greddy D-series manifold. So you should be able to call Greddy or HKS for a gasket.
Make sense...?
Make sense...?
project dc2
05-24-2002 02:09 PM
