questions about b20...
Old Mar 14, 2007 | 03:53 PM
deadline's Avatar
Default questions about b20...
okay..i gotz this b20 long block..if i take off the b20 head and put on the p-75 head (LS) is it a direct swap ?
no flaming on why dont i just get a vtec head....p-75 its all i got
Old Mar 14, 2007 | 04:28 PM
Slurp56's Avatar
Default Re: questions about b20... (deadline)
Yes, its interchangeable. The B20 and LS (b18b1) use the same head.
Old Mar 14, 2007 | 05:06 PM
deadline's Avatar
Default Re: questions about b20... (Slurp56)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Slurp56 &raquo;</TD></TR><TR><TD CLASS="quote">Yes, its interchangeable. The B20 and LS (b18b1) use the same head.
ls timing belt or b20 belt ? head studs same ?
Old Mar 14, 2007 | 05:36 PM
doood's Avatar
been there done that
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by deadline &raquo;</TD></TR><TR><TD CLASS="quote">
ls timing belt or b20 belt ? head studs same ?</TD></TR></TABLE>
all that is the same. only the jdm b20's with p8r heads are different with bigger combustion chambers and valves.
Old Mar 14, 2007 | 05:51 PM
deadline's Avatar
Default Re: questions about b20... (doood)
nice...<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by doood &raquo;</TD></TR><TR><TD CLASS="quote">
all that is the same. only the jdm b20's with p8r heads are different with bigger combustion chambers and valves.</TD></TR></TABLE>
Old Mar 14, 2007 | 06:31 PM
dthug's Avatar
if you have a b20 long block why change the head to the same exact head again?
Old Mar 14, 2007 | 08:17 PM
deadline's Avatar
Default Re: questions about b20... (dthug)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by dthug &raquo;</TD></TR><TR><TD CLASS="quote">if you have a b20 long block why change the head to the same exact head again?</TD></TR></TABLE>
b20 head is same as LS ?
Old Mar 15, 2007 | 11:00 AM
doood's Avatar
b20 head is same as LS ?</TD></TR></TABLE>
you didnt even read the thread did you?
jdm91CrxSi
Sep 26, 2007 07:55 PM
E_F_9
10
Feb 12, 2006 07:32 PM
mycrx7
Oct 2, 2005 02:13 PM
J-Spec EG
May 7, 2004 09:38 PM
Rob Dizzle
Mar 8, 2004 06:12 PM
