timing
Old Mar 14, 2007 | 03:08 PM
whiteboy03si's Avatar
Default timing
where do you adjust the ignition timing. I know how to adjust the timing on the cam via dizzy, I just think my ignition timing is bad. Also, if the ignition timing is off will that cause my ignition coil to go bad quickly?
Old Mar 14, 2007 | 03:12 PM
Padawan's Avatar
Darth ModerVader
Default Re: timing (whiteboy03si)
Base ignition timing is set with the distributor. Cam timing can only be adjusted with an adjustable cam sprocket.
Old Mar 14, 2007 | 03:27 PM
Bense's Avatar
the helms manual explains all of this
Treyschls
Apr 13, 2023 07:04 AM
kirkland08
Feb 13, 2011 08:59 AM
johnwohl
Apr 1, 2008 07:29 PM
Mugen_DC2R
Jun 18, 2007 08:04 AM
has-t
Jul 1, 2003 09:58 AM
