96 spec itr bearing and brake pad questions
Old Mar 14, 2007 | 11:17 AM
Timmay's Avatar
Default 96 spec itr bearing and brake pad questions
my wheel bearings are shot on my 96 spec lug swap.. looking to see what bearing is used.. i was told GSR is the same but doesnt seem like anyone is 100%
and same for the brake pads.. i was told gsr on them.. and im looking for a pad that is low on dust
any insight on this?
Old Mar 14, 2007 | 11:38 AM
charjacq's Avatar
New User
Default Re: 96 spec itr bearing and brake pad questions (Timmay)
You might want to put up more info. Which car? What did you swap out?
Same for pads...
I'm a bit confused on what you're asking really.
Old Mar 14, 2007 | 12:26 PM
Timmay's Avatar
Default Re: 96 spec itr bearing and brake pad questions (charjacq)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by charjacq &raquo;</TD></TR><TR><TD CLASS="quote">You might want to put up more info. Which car? What did you swap out?
Same for pads...
I'm a bit confused on what you're asking really.</TD></TR></TABLE>
car shouldnt matter.. its 96 jdm itr lug swap so every part i have is from that
Old Mar 14, 2007 | 01:10 PM
BlueIntegraBoy's Avatar
96 spec ITR is the same exact brakes as any 94-01 Integra (excl ITR), except that the hub is 4x114.3. Any wheel bearing and brake pad from a 94-01 Integra (excl ITR) will work.
Old Mar 14, 2007 | 02:56 PM
Timmay's Avatar
Default Re: 96 spec itr bearing and brake pad questions (BlueIntegraBoy)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by BlueIntegraBoy &raquo;</TD></TR><TR><TD CLASS="quote">96 spec ITR is the same exact brakes as any 94-01 Integra (excl ITR), except that the hub is 4x114.3. Any wheel bearing and brake pad from a 94-01 Integra (excl ITR) will work.</TD></TR></TABLE>
thanks man you always seem to have good info
KOALA YUMMIES
365
Apr 2, 2014 12:59 PM
mugenef9
Oct 10, 2008 08:00 PM
