radio problem help
Old Mar 14, 2007 | 06:51 AM
h22_crx's Avatar
Default radio problem help
i am puting a cd player is my 97 civic ex the problem is that the stock one was work before i try install the cd player. the stock one works in my crx and the cd player works in my car. the fuse 4 the radio blow so i put a new one in still nothing. u guy think i messed up the wiring system?? help
Old Mar 14, 2007 | 06:53 AM
SkyliteCustomz's Avatar
wtf..speak english..lol..anyways look for exposed wires...could be touching metal and causing the fuse to blow
philosofy1's Avatar
Default Re: radio problem help (h22_crx)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by h22_crx &raquo;</TD></TR><TR><TD CLASS="quote">i am puting a cd player is my 97 civic ex the problem is that the stock one was work before i try install the cd player. the stock one works in my crx and the cd player works in my car. the fuse 4 the radio blow so i put a new one in still nothing. u guy think i messed up the wiring system?? help </TD></TR></TABLE>
most likely the fuse blew again. this means you have a short. remove the radio and double check your wiring, something is grounding out.
i hope you used the aftermarket radio harness for this? you know, the one that connect to the factory harness and then you wire it up to the radio harness.
Old Mar 14, 2007 | 07:08 AM
Civic98KH's Avatar
agree with both responses
Old Mar 14, 2007 | 07:26 AM
h22_crx's Avatar
Default Re: radio problem help (philosofy1)
i use the aftermarket radio harness
Old Mar 14, 2007 | 09:39 AM
h22_crx's Avatar
anyone
Old Mar 14, 2007 | 10:36 AM
deckster333's Avatar
if you aren't sure about the power, run a power wire directly from the battery.
Old Mar 14, 2007 | 10:42 AM
h22_crx's Avatar
Default Re: radio problem help (deckster333)
is there a security setting in the car that would mess up the radio at all?
Old Mar 14, 2007 | 11:07 PM
no
Old Mar 15, 2007 | 05:43 AM
h22_crx's Avatar
Default Re: (SkyliteCP)
i got it working i had to put the yellow wires with the red wires
Old Mar 15, 2007 | 05:13 PM
good job
Old Mar 15, 2007 | 05:18 PM
Padawan's Avatar
Darth ModerVader
Default Re: (h22_crx)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by h22_crx &raquo;</TD></TR><TR><TD CLASS="quote">i got it working i had to put the yellow wires with the red wires</TD></TR></TABLE>
That doesn't sound right. One is supposed to be a constant 12V source, and the other is supposed to be ignition-switched.
BTW, in the future, try the Audio / Security/ Video forum for car audio questions or issues. That's what it's there for.
Old Mar 15, 2007 | 05:33 PM
Projekt_2nr's Avatar
Default Re: (Padawan)
run a constant wire from your battery to replace the white with blue stripe wire if its an eg body style civic, and run the constant too the yellow wire, or else everytime you turn off your car your presets will reset along with the cd, nothing will stazy preset if you leave your yellow and red wire connected to your 12v ignition wire, i ran into this problem yesterday with my brand new alpine headunit, your constant 12v wire is bad on the harness, you can re-run the wire or just have a constant wire running from the battery or any other constant power source thats on your fuse box.
Danthemagicbum
Audio / Security / Video
May 22, 2010 07:02 AM
simplegreenmachine
Aug 17, 2007 07:42 AM
YY
Dec 26, 2005 03:11 PM
jamie_honda_08
Nov 5, 2004 07:19 PM
civic-cpe
Aug 11, 2002 12:21 AM
