dropping a b20b in a del sol and looking to see what I need
Old Mar 13, 2007 | 11:58 PM
210racer's Avatar
Default dropping a b20b in a del sol and looking to see what I need
I am dropping a b20 in a del sol s. I was wondering besides the tranny, motor, mounts, axles, ecu, and harness. I am looking for what else I need.
I was told that I needed the rare shift linkage and a rear bracket. I was trying to make sure if that is all or is there anything else.
Any help will be good and thanks.
Old Mar 14, 2007 | 12:12 AM
MilanoCpe's Avatar
Default Re: dropping a b20b in a del sol and looking to see what I need (210racer)
bump
i might need this info in a couple of months
good luck with the swap
Old Mar 14, 2007 | 12:16 AM
del_slow420's Avatar
Default Re: dropping a b20b in a del sol and looking to see what I need (MilanoCpe)
dude look at the sticky bout what can i swap in my civic same thing
Old Mar 14, 2007 | 12:39 AM
210racer's Avatar
I tried reading them and no info to my question, but thanks though
Old Mar 14, 2007 | 01:38 AM
B18CivicEH2's Avatar
Default Re: (210racer)
you gonna need to convert your motor to OBD1...you gonna need an L bracket UNLESS your del sol is the DOHC Vtec model...alternator bracket....you gonna need 90-93 Integra axles, 94 up Integra axles, 94-97 Del Sol DOHC VTEC axles or 99-00 Civic Si axles...94-97 Del Sol DOHC VTEC linkage..the upper radiator hose for 94 Integra LS...the lower radiator hose for 94 Del Sol DOHC VTEC.OBD1 LS dizzy....94 Integra LS throttle cable...you pretty much converting your motor to OBD1 using OBD1 LS parts..you can keep the motor OBD2 but you gonna need a jumper harness which can rob some of your motors potential (according to hasport)
cody_sandlin
Aug 9, 2013 05:19 AM
ekay08
Apr 23, 2008 09:51 AM
LambertdelSol
Jun 24, 2007 09:04 AM
89JDMcrx
May 22, 2004 11:16 PM
