broken down
okay so my 97 civic hatch just broke down. so i need help in figuring it out what exactly it is. well it started that the clutch didnt feel the same and i couldnt throw it in gear...then when it just slow down cuz it was in nuetrel i couldnt throw it any gear except reverse and it started making like a dragging noise even though i wasnt dragging anything. so i pulled it home with my foot on the clutch all the way and it rolled fine and no grinding but if i let go of the clutch pedal it would make noise
if i can get response it would be greatly appreciated thanks
could be a bad throw out bearing mine is realy noisy and makes it hard to go into revers. ( id replace mine but i am getting a new trans soon) try putting it in forth then in revers that seems to do the trick for my tranny.
well i had that noise b4 and i was told it was somehting bearing and it was hard to throw into reverse but now the noise sounds badddd
and i cant put any gears in and the clutch pedal doesnt feel the same. it feels like really soft
https://honda-tech.com/zerothread?id=1921068
heres another thread about that noise i made earlier today irronically it had been doin it for a while and it had just been getting louder and louder
yeah like the other guy told you it sounds like a throw out bearing if it goes away when you put the clutch in (it takes puts pressure on the bearing so that it cant wilgle around and make noise) its not an expensive part but you need to remove the tranny to replace it. if you are on an older clutch you would probly want to do that at the same time. so you don't have to take the tranny out again when that starts to go.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ekblack9 »</TD></TR><TR><TD CLASS="quote">okay so my 97 civic hatch just broke down. so i need help in figuring it out what exactly it is. well it started that the clutch didnt feel the same and i couldnt throw it in gear...then when it just slow down cuz it was in nuetrel i couldnt throw it any gear except reverse and it started making like a dragging noise even though i wasnt dragging anything. so i pulled it home with my foot on the clutch all the way and it rolled fine and no grinding but if i let go of the clutch pedal it would make noise
if i can get response it would be greatly appreciated thanks</TD></TR></TABLE>
if the clutch pedal is not pressed and you hear the noise is more likely the input shaft bearing not the throwout bearing. TOB makes a noise when the pedal is pressed because thats when its being used.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by mustang5.slow »</TD></TR><TR><TD CLASS="quote">i got a trhow out bearing i could let go . in 323
well some are saying its throw out and some throw in so still unsure which is the prob but the car cant go any where with out it being pulled or towed thats for sure
thx though
thx though
well im out of ideas
if you got the money get it towed to the garage and have them look it over it hard to diagnose from a couple states away
if its a good garage they should be able to tell you what wrong without to much money invested in labor and may be they can get it fixed in that first hour of labor charge too.
hopefully its just a bearing the run between 10 and 40 dollars i believe
good luck man
may be some one else here has a better idea of whats going on
good luck man
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by eg8tuner »</TD></TR><TR><TD CLASS="quote">well im out of ideas
good luck man
thanks for all ur help man.. im pretty sure its gonna be either bearing.
good luck man
</TD></TR></TABLE>thanks for all ur help man.. im pretty sure its gonna be either bearing.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by deckster333 »</TD></TR><TR><TD CLASS="quote">if you bring it to a shop, they will most likely recommend that you replace the clutch and all bearings at once.</TD></TR></TABLE>
oh okay that makes sense...so its surely the bearings? i just noticed that it started leaking a little bit of oil this morning, but its just very little and it didnt do it b4
Tyler Harteau
Jan 4, 2021 08:45 PM
