Is this a timing problem or what?
Old Mar 13, 2007 | 08:49 PM
prcivic91's Avatar
Default Is this a timing problem or what?
First off a little history on my car, Its a 91 civic with the 1.5 dual port in it. I was driving to work today and as I was driving the car would like lose all electrical power it would do this for like a second or so. It did this everytime I would speed up fast and\or shift. The main crank seal is leaking oil on to the timing belt as well. the check engine light is has been on for a while. My question is, could my timing belt have slipped and was that what was causing the electrical lose or is the electrical lose a totally bigger problem. And if my timing slipped and the engine cut off Did I beld the valves or are the valve ok?
Old Mar 14, 2007 | 08:27 AM
prcivic91's Avatar
Default Re: Is this a timing problem or what? (prcivic91)
help, advice, anything
Old Mar 14, 2007 | 11:56 AM
ef_zcvtec's Avatar
first, what code is it? second check your engines grounds, IE the one n the back of the thermostat and all that stuff..
Old Mar 14, 2007 | 08:59 PM
prcivic91's Avatar
Default Re: Is this a timing problem or what? (ef_zcvtec)
Thanks for the tip. the code it was showing was about the coolant themp sensor and I replaced it and it still did'nt go away.
Old Mar 14, 2007 | 09:19 PM
jayturboef's Avatar
is the problem all through the powerband or only at wot
Old Mar 14, 2007 | 09:29 PM
prcivic91's Avatar
Default Re: (jayturboef)
it only lose power when going faster and shifting from first to second and second to third
Old Mar 15, 2007 | 07:39 AM
prcivic91's Avatar
Default Re: (prcivic91)
bump
Old Mar 15, 2007 | 09:08 PM
prcivic91's Avatar
bump
Old Apr 3, 2007 | 11:35 PM
aftershk's Avatar
if you're running a D15b2 and your belt jumps the electrical wouldn't budge.
i was doin 110+ and my belt snapped and nothing happened.
its crazy i didn't bend any valves.
sounds like the alternator belt may have slipped.
90civic-ZC
Nov 21, 2011 06:45 PM
DraginTeg93
Jan 29, 2010 12:02 AM
musicncars
Jun 13, 2005 11:16 PM
T--Rex
Jul 4, 2004 04:18 PM
Jaydeep
Apr 28, 2004 07:15 PM
