Guys need some help check engine light is on w/hondata
Old Mar 13, 2007 | 06:02 PM
vtecgod's Avatar
Default Guys need some help check engine light is on w/hondata
Well guys have a 99 civic coupe w/b16 swap running obd1 conversion with p28 hondata chip, the check engine light is on i had the bulb out of it for a while now. I just recently put the bulb back in and the light was on i took it up to my buddie at the honda shop and he tried to jump it and no responce. The car is running fine but worried that something else is going to go wrong. Is this a comp problem an o2 sensor or maybe the chip is bad? Need some help on this guys thanks.
Old Mar 13, 2007 | 06:20 PM
vtecgod's Avatar
Default Re: Guys need some help check engine light is on w/hondata (vtecgod)
Guys the engine is an obd2 motor with the obd1 conversion harness with the hondata is it worth trying another chip or plugging in a stock p28 and seeing if the light comes on or not?
Old Mar 14, 2007 | 09:28 AM
vtecgod's Avatar
bump up
Old Mar 14, 2007 | 04:25 PM
vtecgod's Avatar
any info would help and friend suggested me to call hondata on this.
Old Mar 14, 2007 | 04:28 PM
pdiggitydogg's Avatar
if your buddy tried to check the code, using the obd2 port, it wouldnt respond
or, did he jump it using the connector at the passenger kick-panel?
Old Mar 17, 2007 | 10:52 AM
vtecgod's Avatar
Default Re: (pdiggitydogg)
no he jumped it at the kick panel.
Old Mar 17, 2007 | 11:27 AM
Agent Zero's Avatar
Default Re: (vtecgod)
This may sound kinda dumb, but when I had my Hondata chipped to my p28 I had the same problem. Check the connection to the little blue box. Mine was loose and threw a CEL. Hope that helps.
Old Mar 17, 2007 | 11:42 AM
vtecgod's Avatar
Default Re: (Agent Zero)
pm'ed.
Old Mar 25, 2007 | 07:40 AM
vtecgod's Avatar
bumpie thanx
Old Mar 27, 2007 | 09:09 AM
Spunkster's Avatar
Take it to a Hondata dealer that can datalog the error code using their Hondata software.
poormans_typer69
Feb 16, 2008 02:04 PM
hybridmiklo
10
Aug 6, 2007 02:24 PM
martini
Apr 22, 2003 11:27 PM
