Skunk2 stg2, pro1, pro2 cams vs JDM Type S cams?
I'm planning on getting new cams in the near future for my H22 and I was wondering what you guys think about the Skunk2 stage2, pro1, and pro2. This is my first motor that I'm actually building so I don't know much about the differences except what I read on the descriptions on JHP and such. My current setup consists of:
Head:
Supertech valves, valvesprings, retainers
JDM Type S cams
Block:
JDM Oversized Type S pistons & rings
Balance shafts removed
AEM CAI
JIC Bullet Exhaust
Not sure what kind of header but here's a pic. I believe it was custom but I'm not sure.
sorry that's the only pic i have at the moment. took it while i was sanding it down. Which is why it's shiny on left and nasty on right
I think that's it...
Which cam would be the most effective for a street/daily driver application? How do these Skunk2 cams compare to the type s cams? Also, I'd like to know why the Type S cams are more expensive than the Skunk2 cams on JHPusa.com. Thanks in advance.
Modified by j0hn-0h at 6:35 PM 3/13/2007
Head:
JDM Type S cams
Block:
AEM CAI
JIC Bullet Exhaust
Check out the recent thread about the skunk2 Pro1's, sorry im not much help here but they showed good gains.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by VtecKiDD »</TD></TR><TR><TD CLASS="quote">PRO1s</TD></TR></TABLE>
listen to THE MAN
listen to THE MAN
vteckidd.. have you tried pro2's on a stock motor yet?? if i can find extra funds to put my good head on my stock block id like to get my hands on a set of pro2's
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JDogg »</TD></TR><TR><TD CLASS="quote">vteckidd.. have you tried pro2's on a stock motor yet?? if i can find extra funds to put my good head on my stock block id like to get my hands on a set of pro2's</TD></TR></TABLE>
nah i havent , i wanted to try some on Jasons motor before it blew up
the crower 3's on a stock motor only extend hte peak out.. they make maybe 8-10hp more PAST where the stock cams fall off at. they dont pick up anything below where the stock cams peak at.
I've used Skunk2 Pro 2's in my H22 build (Type-S pistons, high compression valves, skimmed block, Skunk2 valvetrain). I also went with a good I/H/E setup, P&P head, ported IM, 68mm TB & standalone ECU. It's due back from the engine builders & tuners next weekend, so I'll post up the results. You'll need decent compression for the Pro 2's, so I'm hoping I've got enough with the above
i wanna see a dyno of pro2's vs. stock cams as well, i wonder how they do on stock comp...
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SkankyEJ7 »</TD></TR><TR><TD CLASS="quote">
listen to THE MAN</TD></TR></TABLE>
listen to him
he knowsss his JDM junt
listen to THE MAN</TD></TR></TABLE>listen to him
Look at the date man that was 4 years ago and yes plenty of people are doing although i think they would make more with stage twos or pro ones . The pro 2s do make power.
