Oil Pressure gauge
Old Mar 13, 2007 | 02:21 PM
nicko360's Avatar
* B A N N E D *
Default Oil Pressure gauge
Has anyone installed an oil pressure on a d16z6? the autometer instructions are really vauge, any help is appreciated
Old Mar 14, 2007 | 10:42 AM
nicko360's Avatar
* B A N N E D *
Default Re: Oil Pressure gauge (nicko360)
bump
Old Mar 14, 2007 | 11:30 AM
civicst's Avatar
yeah its easy, remove the oem oil press sensor by the filter and install the new sender. did you get a mechanical or electric gauge? i will provide pics if necissary.
Old Mar 14, 2007 | 11:56 AM
pdiggitydogg's Avatar
If you dont run an oil filter sandwich adapter, with ports, you need to run a line from the pressure switch port, on the back of the block.
From the hose, Tee it off to add your pressure gauge and a spot for the factory switch.
If electrical, you will just attach the sending unit to the Tee and run a wire to the gauge.
If mechanical (kinda dumb), just run the line from the Tee to the gauge inside the car (and hope you dont leak, spraying oil everywhere inside).
The reason for the additional line, is because attaching any weight to the oil port at the back of the block, commonly leads to broken ****
If you want more information, search - this has been covered
Old Mar 14, 2007 | 02:34 PM
nicko360's Avatar
* B A N N E D *
Default Re: Oil Pressure gauge (civicst)
its a mechancial autometer ultralight gauge, will i be able ot do this w/o pulling the engine?
Old Mar 14, 2007 | 02:52 PM
yes...
crawl under there and you will see the factory oil switch next to the filter.
The thread is 1/8 bspt...so unless you feel like crossthreading a 1/8 npt fitting, you will also need an adapter
lude98SH
Jan 6, 2008 10:19 AM
95LStizzy
Mar 12, 2006 12:35 PM
Super_Eg6
May 5, 2004 10:48 PM
dualknuttz1
Apr 28, 2003 02:57 PM
