saab turbo into civic need input!?!?!?!?!?
Old Mar 13, 2007 | 07:52 AM
sladed16y8's Avatar
Default saab turbo into civic need input!?!?!?!?!?
hey i have a 97 civic ex d16y8 and i just picked up a t25 from a saab at a junkyard for cheap. My question is should i use this t25 and get a t2 to t3 adapter flange and go from there, or get another turbo thats already t3? and the turbo is made by garret and just has alittle play! thanks!
Old Mar 13, 2007 | 07:55 AM
Sanda1s's Avatar
Default Re: saab turbo into civic need input!?!?!?!?!? (sladed16y8)
you can use that, if thats what you want to do. If you have the extra cash a different turbo might offer more options for you
Old Mar 13, 2007 | 08:25 AM
yee SERIOUS's Avatar
well, the decision is really yours. you could go either route. but if you already have a manifold that is flanged for a t3, then sell that t25 and get a t3 turbo.
don't make yourself grow a headache
Old Mar 13, 2007 | 08:27 AM
sladed16y8's Avatar
Default Re: (kidsafe yee)
well i dont have a many yet but i was going to get the adapter plate because the only turbomanifolds i find are all t3 flange
Old Mar 13, 2007 | 08:45 AM
if u don't plan to get a hf manifold and get an adapter plate or get a greddy manifold, then i would just sell the t25.
t25's are great for small setups, but it's just up to you on how you want your setup to be. i would definitely choose the turbo first and build a kit from there.
and yes, most manifolds are t3 flanged. you can always run a decent size t3 that will spool just as fast a t25.....and possibly make more power.
Old Mar 13, 2007 | 09:02 AM
siregcivic's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by kidsafe yee &raquo;</TD></TR><TR><TD CLASS="quote">if u don't plan to get a hf manifold and get an adapter plate or get a greddy manifold, then i would just sell the t25.
and yes, most manifolds are t3 flanged. you can always run a decent size t3 that will spool just as fast a t25.....and possibly make more power. </TD></TR></TABLE>
^^^^^ yup.. t3 is the most common flange.. t3 off a saab turbo is also common..go look around and good luck
sladed16y8
Mar 13, 2007 01:00 PM
b18cls1
Sep 18, 2003 03:19 PM
EV1L SI
Jul 13, 2003 11:12 AM
