Taking Off Spoiler
You can find plastic caps/plugs to fit the holes, then paint them to match and seal them with silicone adhesive. That is probably the most cost-effective option.
pick up a used trunk from someone local
fiberglass/bondo
welding/grinding
or the plug option but be careful that its sealed right or water could get in their and rust can form.
fiberglass/bondo
welding/grinding
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Synbios »</TD></TR><TR><TD CLASS="quote">Where can you pick up some plastic caps?</TD></TR></TABLE>
I got mine at the body shop, but you should also be able to find some at a hardware or auto parts store.
welding would be a good idea, but make sure you "water damn" so you dont warp the decklid.
water damning is basically taking a soaked rag and wrapping it around the area you are welding, it absorbs heat to minimize warping the decklid.
you can use something called tiger hair instead of bondo, its a little stronger material, has fibers in it. so it might not fall through as much.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 92ehatch »</TD></TR><TR><TD CLASS="quote">welding would be a good idea, but make sure you "water damn" so you dont warp the decklid.
you can use something called tiger hair instead of bondo, its a little stronger material, has fibers in it. so it might not fall through as much.</TD></TR></TABLE>
Thanks, I'll try to look for that Tiger Hair.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by EK_B »</TD></TR><TR><TD CLASS="quote">
Thanks, I'll try to look for that Tiger Hair.</TD></TR></TABLE>
gorrilla hair is what ur looking for.
its a fiberglass/bondo already mixed together. all you have to do is add hardner.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by dohcdelsol »</TD></TR><TR><TD CLASS="quote">gorrilla hair is what ur looking for.
its a fiberglass/bondo already mixed together. all you have to do is add hardner.</TD></TR></TABLE>
same thing, diff name
dawrenn
27
Feb 13, 2005 04:19 PM
Buktheng
Dec 18, 2004 09:38 AM
