noises help
Old Mar 13, 2007 | 07:25 AM
ekblack9's Avatar
Default noises help
okay so heres the deal. my car is making some ugly kind of a grind noise. first when its idling it does it and as soon as i put my clutch pedal all the way in it stops.
when i take off it doesnt do it again till like 3,500 rpms and its louder and faster.
everything is performing the same but its just making that noise.
oh and i have a 97 civic hatch dx if that helps. any help is greatly appreciated thanks
Old Mar 13, 2007 | 07:27 AM
na+b18c_hatch's Avatar
could be a heat shield. or sometimes the stock exhaust manifold will rattle inside and make that kind of noise.
Old Mar 13, 2007 | 07:33 AM
crossbones's Avatar
Does it sound a bit like two knives scratching together?? mine made that noise at certain revs, and as said before it was the heat sheild above the cat. Rip it off you don't need it
Old Mar 13, 2007 | 07:47 AM
ekblack9's Avatar
it didnt do it before is what also is wierd..but it sometimes also makes the noise when im driving and i switch gears from the point i put the clutch in and take it out the gear and throw it to the next. but ill try the heat shiled also
Old Mar 13, 2007 | 07:48 AM
AntiochOG's Avatar
Sounds like your input shaft bearing to me.
Old Mar 13, 2007 | 07:50 AM
Sanda1s's Avatar
Default Re: (AntiochOG)
its your throw out bearing... cheap but a pain in the *** to change. You might as well put in a new clutch while your at it.
Old Mar 13, 2007 | 07:51 AM
ekblack9's Avatar
dont know much about that but how much does it run to fix something like that?
by the way thanks for the replies guys : )
Old Mar 13, 2007 | 07:55 AM
ekblack9's Avatar
i wouldnt know to do that myself but how much would they charge if i took it to a shop
GIL7198
Transmission & Drivetrain
Jan 9, 2011 11:18 AM
looneytoonz
Nov 10, 2007 06:14 AM
azteggi
Jan 5, 2005 02:53 PM
