LS in ek what throttle cable
Old Mar 13, 2007 | 03:11 AM
7808's Avatar
Default LS in ek what throttle cable
my friend put a ls motor in his 97 civic, we need to know what throttle cable we should use
Old Mar 13, 2007 | 06:01 AM
ek4_b16a's Avatar
Default Re: LS in ek what throttle cable (7808)
ummm you can't use the single cam throttle cable...too short...gsr is made differently so you are stuck with an ls throttle cable...you can use one from a da..it'll still work...gl with the swap
Old Mar 17, 2007 | 08:39 PM
7808's Avatar
civic one is too short fosure?
Old Mar 17, 2007 | 10:05 PM
virus.EK's Avatar
Default Re: (7808)
Used an LS with my swap but didn't bother to try the civic.
Old Mar 18, 2007 | 12:35 AM
Eran's Avatar
HT White Ops
I used my LS cable on my LS motor .... wild concepts.
Old Mar 18, 2007 | 07:06 AM
pdiggitydogg's Avatar
civic cable w/ my b18b swap...
Old Mar 18, 2007 | 07:46 AM
JDMKid71's Avatar
Default Re: (pdiggitydogg)
Im using the OEM GSR cable in my EK with the GSR swap.. but the intake manny is diff than a LS.. so it might be a shorter or longer cable than what your looking for.. but i know that its a tight fit.... good luck
Old Mar 18, 2007 | 09:20 AM
stevil_knevil's Avatar
Default Re: (JDMKid71)
I used an EX throttle cable in my ek hatch. I did the ex manifold swap when I still had my stock d16y7 in. I did an ls swap in mine, and used the same throttle cable. Perfect length.
Old Mar 18, 2007 | 01:11 PM
7808's Avatar
Default Re: (Eran)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Eran &raquo;</TD></TR><TR><TD CLASS="quote">I used my LS cable on my LS motor .... wild concepts.</TD></TR></TABLE>well the swap didnt have a cable neither did the car.. not like we had both to try
jthrasher1
Jun 19, 2010 09:24 PM
bori bori
Dec 27, 2009 01:25 PM
g0tgot
Oct 11, 2008 07:50 AM
widecoupe
Oct 2, 2001 07:54 AM
