HOW TO install rear LCA/Swaybar ??
Old Mar 12, 2007 | 10:53 PM
SoyMilk's Avatar
Default HOW TO install rear LCA/Swaybar ??
anybody know how to install rear Swaybar with Adjustable endlinks replacing the oem one.. and also LCA replacaing the oem one for a 96 coupe
what tools do i need and what are the steps
Old Mar 12, 2007 | 11:09 PM
BlueIntegraBoy's Avatar
Default Re: HOW TO install rear LCA/Swaybar ?? (ShrimpCrab)
Similar procedure...
http://importnut.net/swaybar.htm
Replacing the LCA is pretty straightfoward. Bolt off and bolt off. Put some load on the suspension before tightening the LCA bolts.
Old Mar 13, 2007 | 01:36 AM
SoyMilk's Avatar
Default Re: HOW TO install rear LCA/Swaybar ?? (BlueIntegraBoy)
iam a beginner, i kind of get that but is still confusing.
Old Mar 13, 2007 | 12:40 PM
SoyMilk's Avatar
anyone know??
Old Mar 13, 2007 | 12:45 PM
excivicboy96's Avatar
https://honda-tech.com/zerothread?id=1452650&page=1
Old Mar 13, 2007 | 01:29 PM
Mistermark's Avatar
what part are you confused about?
Old Mar 13, 2007 | 07:28 PM
SoyMilk's Avatar
Default Re: (Mistermark)
the steps to taking out the bolts .. or can i just take out the lca first or sway bar does it matter?
Old Mar 13, 2007 | 07:31 PM
MitsukillinS2K's Avatar
17mm socket was all i needed. the install is pretty strait foreward
Old Mar 13, 2007 | 10:32 PM
SoyMilk's Avatar
Default Re: (MitsukillinS2K)
is it straight forward enough to type it down?
Old Mar 13, 2007 | 10:34 PM
Eran's Avatar
HT White Ops
Here, https://honda-tech.com/zerothread?id=1906897 ....
You have a step-by-step writeup and pictures ....
If you are still confused, I suggest taking it to a speed shop and pay someone to install it.
undertheradar
35
May 16, 2006 10:57 PM
LaOstha
Aug 20, 2005 10:29 AM
p0pe
Jan 13, 2004 12:36 PM
Raocorp
Jun 18, 2003 02:23 PM
