any special tricks when install a rear sway bar?
I'll be installing an Si rear swaybar on my buddies 99 EX this weekend and I was just wondering how difficult the install will be and if anybody has any tricks. How should I jack up the car to put this thing on? should I use those drive on ramps or the jack points and put it on jack stands. I'm guessing that if I take the tires off and use jack stands it maybe easier cuz there will be no weight/force on the control arms.
Do I have to centre or position this thing correctly or is it a straight install. I have an Si, and looking at my car it seems like a fairly straight forward install. I am mechanically incline and i have lots of tools, but I have never installed a rear swaybar before.......
any help would be good
Thanks.
Thanks.
Re: any special tricks when install a rear sway bar? (SkyeC)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SkyeC »</TD></TR><TR><TD CLASS="quote">Easy install.
Tighten the endlink bolts with the car on the ground.</TD></TR></TABLE>
yep......
and the bolts that hold the brackets on are a pain in the *** to tighten
yep......
Re: any special tricks when install a rear sway bar? (u2civic1)
Hey, my car is just lowered ~1.5" and I cannot squeeze under there and have enough room to work! And I am just 160lbs!
Re: any special tricks when install a rear sway bar? (FifthGearOnline)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by FifthGearOnline »</TD></TR><TR><TD CLASS="quote">
yep......
and the bolts that hold the brackets on are a pain in the *** to tighten </TD></TR></TABLE>
what makes them difficult to tighten?
yep......
kcjohnnyboy
Suspension & Brakes
03-23-2008 06:31 PM
CTRwannaB
04-23-2006 10:51 PM
