IACV causing me to run rich?
Old Mar 12, 2007 | 05:49 PM
MilanoCivic97's Avatar
Default IACV causing me to run rich?
my car has been running real rich for the past few months...enough to turn the spark plugs black in a matter of weeks. about a month ago i got autozone to plug into my ecu and i showed codes for the map sensor, iacv, and a misfire on cylinder 4. the isfire was due to spark plugs and i replaced the map sensor a few days ago hoping that would fix it. the only problem left it the iacv. my idle has been fluctuating for some time between 1k n 2k rpms. i thought i fixed it by cleaning it out but the problem came back. could my bad iacv be causing me to run rich?
Old Mar 12, 2007 | 07:12 PM
Default Re: IACV causing me to run rich? (MilanoCivic97)
bump. i really need an answer...
Old Mar 13, 2007 | 05:05 AM
morning bump...
Old Mar 13, 2007 | 07:03 AM
Boostedb20EH2's Avatar
Setup please?
More details
Old Mar 13, 2007 | 07:54 AM
Smoak's Avatar
Default Re: IACV causing me to run rich? (Boostedb20EH2)
YES I HAD TO REPLACE MINE LIKE 2 MONTHS AGO. YOU HAVE WEIRED IDLE AND SHITTY GAS MILEAGE RIGHT? YOU NEED TO GET A NEW IACV. IT IS LIKE 120 FOR A NEW ONE (ATLEAST FOR A B16A2)
Old Mar 13, 2007 | 09:28 AM
Default Re: IACV causing me to run rich? (Smoak)
its a d16y8...stock. i really dont want to have to replace the damn thing. i was thinking throttle body cleaner and wd40. good idea?
Old Mar 13, 2007 | 10:50 AM
93FlatBlackHatch's Avatar
If your iacv is throwing a code then I dont think there is a way around fixing it without buying a new one. Unless it was really clogged but you already said you cleaned it.
Old Mar 13, 2007 | 11:24 AM
Default Re: (93FlatBlackHatch)
yea it is throwing a code...i just plugged it in today. it came up with the same code twice, at least thats what the guy at autozone said. when i clean it it does get better for about a day, maybe i should clean deeper...
Old Mar 13, 2007 | 11:37 AM
Syndacate's Avatar
Default Re: (MilanoCivic97)
Usually you can't just clean and throw back on the IACV like you can the FITV.
Just replace it.
Old Mar 13, 2007 | 05:13 PM
Default Re: (Syndacate)
damn. guess ill order one from honda tomorrow for 130...autozone wants 160
Old Mar 13, 2007 | 05:18 PM
Why dont you buy one off some one on the board for wayy cheaper?
Old Mar 13, 2007 | 05:45 PM
Default Re: (Boostedb20EH2)
i'd think it would be better to get one brand new dont you?
Old Mar 13, 2007 | 05:50 PM
Depends..you can can get one for cheap with nothing wrong with it. Or i guess you could get a brand new one if you really wanted.
LST2
Jan 20, 2008 06:37 AM
Nos4R2
Apr 20, 2007 07:22 PM
VTECth1s
May 31, 2006 05:26 AM
N1ghtM0nkey
Mar 26, 2006 05:45 PM
jdm.ej
Nov 16, 2005 05:08 PM
