B16A block with GSR JDM Head
Hi, the last saturday i made **** my old ls-vtec setup.
I have a JDM B16A block stock bore. The block is in perfect conditions.
And i also have a JDM GSR Head.
I would like to put some CTR pistons in it. But... what rods do i need? And... what kind of compression would i get from this? is this worth it? I mean, i have almost everything, and i would like to get at least almost the same compression as i had in my ls-vtec.
My ls-vtec setup was... B18B1 Block, P73 .20 Pistons, and JDM GSR Head.
The compression was good enough to blow up the motor twice.
I would appreciate your opinions ASAP.
Thx, from Mexicali... Herzeleid.
i run that
b16 block with gsr head
around 11.5/1 comp
dynod at 157@8400
afrs were dead on at 13 we ran out of time to keep pulling fuel
i love it this little combo loves to rev
for anyone that is gonna build this make sure you have a good set of cams/srings/retainers and get your rods shotpeened or buy some good ones its no fun to realize that that is the weakness in my build after it took me so long to get it together
around 11.5/1 comp
dynod at 157@8400
A friend of mine is selling me a b18b1 block.
If i put the B18B1 with the GSR head and the CTR pistons... is it prone to crack? ha ha.
i know is a dumb question, but with the LS rods and all the compression stuff, it gets really nasty. And i wanna know if it would be reliable at 91 octane gas. Daily driving of course.
All right, if i get the LS BLOCK... and i add the ARP rod bolts and ARP head studs... i have already bought the CTR pistons, and i already have the GSR head. If i use 91 octane gas... should i have problems? Thank you.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by mmuller »</TD></TR><TR><TD CLASS="quote">PCT pistons with b16 block and gsr head wont work.
how will it not work?
p28 pistons stick out of the block too genious! ask your local tuner, if it is built and tuned corectly you shouldn't have any problems
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by nateg »</TD></TR><TR><TD CLASS="quote">p28 pistons stick out of the block too genious! ask your local tuner, if it is built and tuned corectly you shouldn't have any problems</TD></TR></TABLE>
omg..
omg..
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by nateg »</TD></TR><TR><TD CLASS="quote">let me find the pics </TD></TR></TABLE>
are you sure you want to stick with your P28 pistons comment?
EGinNY
Dec 8, 2004 10:54 PM
