Problems after auto to manual swap *SERCHED
Old Mar 11, 2007 | 12:23 PM
joshb_'s Avatar
Default Problems after auto to manual swap *SEARCHED
I have spent about 2 hours searching trying to find the answer but I have no luck. I finished my auto to manual swap on my 94 coupe and I'm having some problems with the wiring on the harness that used to plug into the auto shifter assembly. I connect the 2 fat black wires together just to see if i could get it to start, and I get nothing. I then took a wire and ran it from the positive batt terminal to the smaller starter post with the key to on and it fired right up just fine. Any ideas on what could be causing the car not to start? I even de pined the 2 fat wires and twisted them together to make sure they had perfect connection.
Old Mar 11, 2007 | 01:03 PM
I Have an STD's Avatar
wrenchin'
Default Re: Problems after auto to manual swap *SEARCHED (joshb_)
bump for you cause i made your car start from 30 miles away, lol
Old Mar 11, 2007 | 03:27 PM
joshb_'s Avatar
Default Re: Problems after auto to manual swap *SEARCHED (I Have an STD)
bump, anyone got any ideas
Old Mar 11, 2007 | 04:54 PM
joshb_'s Avatar
Just re-checked all grounds and fuses still nothing.
Old Mar 11, 2007 | 04:59 PM
B18CivicEH2's Avatar
Default Re: (joshb_)
here you go
https://honda-tech.com/zerothread?id=1337459
at the bottom of the write up, he explains on how to wire the shifter wires....go over it and see if its done right...good luck
"Wiring!
Now this is pretty easy, but then again i love electrical. But all you need to do is connect 5 wires total. One of the plugs that you disconnected from the auto shifter is a 14P plug. Cut the plug off. Your going to have a 2 thick blk wires and 1 blk/blu wire, Solder those 3 together. Those together lets your car think its in park and releases the key and starts your car. Important
Next there is a yel/red wire and a grn/blk wire. Doesnt matter what way they go they do the same. These are for your reverse lights. Connect some line to them and run it through the firewall to your reverse light switch. And your set"
Old Mar 11, 2007 | 05:51 PM
joshb_'s Avatar
Default Re: (B18CivicEH2)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by B18CivicEH2 &raquo;</TD></TR><TR><TD CLASS="quote">here you go
"Wiring!
Next there is a yel/red wire and a grn/blk wire. Doesnt matter what way they go they do the same. These are for your reverse lights. Connect some line to them and run it through the firewall to your reverse light switch. And your set"</TD></TR></TABLE>
I have gone over it and done it just like that. Except for the fact that I think just the ek has the black with blue stripe? I have connected the 2 fats and the black to the green with white stripe and I still get nothing. Any other suggestions?
Old Mar 11, 2007 | 07:22 PM
joshb_'s Avatar
bump
Old Mar 11, 2007 | 07:37 PM
Luserkid's Avatar
Check your fuses. If the 2 blk wires are together then it should give the signal to the starter to turn over.
Old Mar 11, 2007 | 08:28 PM
joshb_'s Avatar
Default Re: (Luserkid)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Luserkid &raquo;</TD></TR><TR><TD CLASS="quote">Check your fuses. If the 2 blk wires are together then it should give the signal to the starter to turn over. </TD></TR></TABLE>
any fuses in paticular? i checked the starter signal under the dash already and it looked fine, maybe ill throw a new one in to be sure...
Old Mar 11, 2007 | 08:31 PM
Luserkid's Avatar
Just check them all along with your main relay. Reason being is that your car should act exactly the same as before if those 2 are connected. Now you are connecting the 2 thick wires that are in the center of the plug right?
Old Mar 12, 2007 | 07:55 AM
joshb_'s Avatar
Yep, I de pined them and connected them up....I can hear the main relay click and the fuel pump primes so I know that is all good. The only way I have got the car to start is hot wiring the smaller starter terminal straight to the positive side of the battery with the key switched to the on position.
Old Mar 12, 2007 | 12:43 PM
joshb_'s Avatar
any other thoughts?
Old Mar 12, 2007 | 12:54 PM
dad0c402's Avatar
what you trying to do is trick the car to think it's still in park. I say exam your auto shift assembly and if you have to, reconnect it back together. There should be a slider, which tells your car what position the shifter is in. After you find that figure out which one is for the park position, mostly likely the furthest forward. Then connect that wire with the fat ones. I don't know exactly how a 5th gen civic assembly looks like, but if it's anything similar to 6th gen, then that should help.
Old Mar 12, 2007 | 01:07 PM
joshb_'s Avatar
Default Re: (dad0c402)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by dad0c402 &raquo;</TD></TR><TR><TD CLASS="quote">what you trying to do is trick the car to think it's still in park. I say exam your auto shift assembly and if you have to, reconnect it back together. There should be a slider, which tells your car what position the shifter is in. After you find that figure out which one is for the park position, mostly likely the furthest forward. Then connect that wire with the fat ones. I don't know exactly how a 5th gen civic assembly looks like, but if it's anything similar to 6th gen, then that should help.</TD></TR></TABLE>
I was so happy to get that auto **** out I threw it away so I have no way of doing that. I have tried basically every wire combo and still nothing is working.
Old Mar 12, 2007 | 09:12 PM
dad0c402's Avatar
Sorry if this replay is a little late but I recently got home from work. Dug through some stuff and found the following two images about the wiring that might be of interest. There's something that seems to be going on with the blk/wht wire going from the start position of the ignition switch (left corner of pic A) to the shift position console and leaving through a red/blk wire to the ecu, possibly to give the ecu a signal to start the car. And also in pic B there's some grn/wht wire involved, but it may just be used to illuminate the P in your guages.
pic A http://i10.tinypic.com/2zdzipg.gif
pic B http://i10.tinypic.com/3ziwpq0.gif
I am still on my first project car so this is about as much as I know.
Old Mar 12, 2007 | 09:56 PM
777's Avatar
777
What ecu are you running?
Old Mar 13, 2007 | 07:52 AM
Luserkid's Avatar
Default Re: (KILLA_EK9)
The ecu and auto shifter being in park doesnt matter, those are myths. If the Park one matters he shouldnt be able to take his key out, which i believe he can. Theres something wrong in your connection somewhere that your going to have to look. Either the little tab on the starter or somewhere in the harness.
Old Mar 14, 2007 | 07:42 AM
joshb_'s Avatar
I am going to try to run a wire striaght form the black/white wire to the starter and see if that will fix the problem....I need to get the car back on the road.
Old Mar 14, 2007 | 03:36 PM
joshb_'s Avatar
Connected the black wire with the white stripe to the smaller terminal on the battery and the car starts fine and the key comes out.....problem solved!
Old Mar 14, 2007 | 06:05 PM
wrenchin'
you had better fuse that new wire josh, that could start a fire if it were to ground out
Old Mar 15, 2007 | 05:41 AM
joshb_'s Avatar
Default Re: (I Have an STD)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by I Have an STD &raquo;</TD></TR><TR><TD CLASS="quote">you had better fuse that new wire josh, that could start a fire if it were to ground out</TD></TR></TABLE>
what amperage do u suggest?
Robert_West01
Jun 19, 2019 12:53 PM
TheDonOG
Jan 1, 2017 01:25 PM
a1320honda
Aug 30, 2013 12:17 PM
DA9Sleeper
Aug 10, 2010 10:44 AM
pr0jektdc2
May 9, 2006 07:18 PM
