Del Sol cluster removal.
Old Mar 11, 2007 | 10:07 AM
honda_racing101's Avatar
Default Del Sol cluster removal.
Anyone have a how to or a couple of tips on removing the cluster? I know there are EG cluster how to's but they are different.
Thanks in advance.
Old Mar 11, 2007 | 10:10 AM
Bakeoff's Avatar
Default Re: Del Sol cluster removal. (honda_racing101)
I'll type one up. Gimmie a few minutes.
Old Mar 11, 2007 | 10:13 AM
Bakeoff's Avatar
Default Re: Del Sol cluster removal. (Bakeoff)
First, remove the two screws that hold in the panel above the cluster. Once removed, pull that panel out. While pulled forward, unplug the green plugs for aux lights, cruise, hazards, etc. The are all different, so you can't mix them up.
Next, there is a metal bracket at the top of the gauge cluster. Unscrew the one screw that connects it to the dash.
On each side of the gauge cluster, remove one screw. After that, pull the cluster forward and unplug each plug.
Voila.
Old Mar 11, 2007 | 04:28 PM
Thanks man, that worked like a charm.
Old Mar 11, 2007 | 04:31 PM
Vt3c_eg's Avatar
Default Re: (honda_racing101)
come takeing off a cluster is a piece of cake! shouldn't even need a write for it.
Old Mar 11, 2007 | 05:24 PM
Targa250R's Avatar
be professional
Default Re: (Vt3c_eg)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Vt3c_eg &raquo;</TD></TR><TR><TD CLASS="quote">come takeing off a cluster is a piece of cake! shouldn't even need a write for it. </TD></TR></TABLE>
Grow up.
He's 16. You have to start somewhere. Even I need instructions every once in a while to take something apart without breaking it, and I disassemble Honda cars for a living.
Old Mar 12, 2007 | 06:22 PM
Thanks targa250R
I wanted the how to so I knew what to expect. The last thing I wanted was to break something.
If you think im incapable, then thats your opinion, but yes I am 16 and im doing a full b series swap, a brake swap all the way around with discs on the rear, adding A/C, swapping power steering into the car, and ALOT more. Oh, did I mention I havent done very much to a car before.
Its a learning process, and I'll take all the help I can get.
Old Mar 12, 2007 | 07:57 PM
Targa250R's Avatar
be professional
Do yourself a favor and pick up one of these:
http://www.helminc.com/helm/pr...0D913
Old Mar 13, 2007 | 03:47 PM
Does that one have a blue cover?
If so then I do have one, but one of my friends 'borrowed it' and he's had it for a few months.
I'll def get it back.
slpr_civic93
May 15, 2006 04:45 PM
StevesSol
Jan 27, 2003 03:09 PM
geminis2k
Jan 24, 2003 11:22 AM
bgod
Dec 17, 2002 12:12 PM
bgod
Dec 17, 2002 10:53 AM
