wiring??????
Old Mar 10, 2007 | 10:28 PM
Vcastro's Avatar
Default wiring??????
how do i wire my air/fuel gauge to the ecu????
Old Mar 10, 2007 | 10:43 PM
gato5254's Avatar
Default Re: wiring?????? (Vcastro)
ok
Old Mar 10, 2007 | 10:49 PM
S2k Hybrid's Avatar
What gato meant to say was
-if does not have directions, try a search and you should come up with an answer.
Old Mar 10, 2007 | 11:29 PM
gato5254's Avatar
Default Re: wiring?????? (S2k Hybrid)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by S2k Hybrid &raquo;</TD></TR><TR><TD CLASS="quote">What gato meant to say was
yep
Old Mar 10, 2007 | 11:34 PM
Eran's Avatar
HT White Ops
You two are ******* worthless. At least help the guy.
Here's a how-to with some pictures. It's really easy. You wire power to a 12v ignition-dependent source, ground to chassis, and signal to the O2 sensor wire on your ECU wire or directly to the O2 sensor.
How-To With Pics:
http://www.team-integra.net/se...D=668
OBD1 ECU Wires:
http://technet.ff-squad.com/wiring.obd1.htm
OBD2A ECU Wires:
http://technet.ff-squad.com/wiring.obd2a.htm
OBD2B ECU Wires:
http://technet.ff-squad.com/wiring.obd2b.htm
Old Mar 10, 2007 | 11:49 PM
Projekt_2nr's Avatar
Default Re: (Eran)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Eran &raquo;</TD></TR><TR><TD CLASS="quote">You two are ******* worthless. At least help the guy.
also you can try
http://www.egauges.com/pdf/AutoMeter/837j.pdf
Old Mar 11, 2007 | 05:20 AM
Vcastro's Avatar
Default Re: (Eran)
thans for the help
camp_kill_yourself
Jan 5, 2007 11:44 AM
J Rob
Dec 18, 2005 03:24 PM
hi mom
Jan 4, 2005 10:39 AM
StupidSlowRSX
May 11, 2004 06:11 PM
JCracer723
Dec 4, 2003 06:15 PM
