Need help, tuner really did a number on me this time :( 266whp/13psi/sc61
Old Mar 10, 2007 | 04:12 PM
90teg's Avatar
Default Need help, tuner really did a number on me this time :( 266whp/14psi/sc61
Setup:
stock b18c1 with 6153miles on it (fresh rebuild)
3mm headgasket
victor x intake manifold
ramhorn manifold
precision SC6152S (brand new)
precision 1000cc's
3" dp with 3"cat with full 3"exhaust no muffler
ctr cams
motorola map sensor
Well now that I have that out the way this is what my dyno graph used to look like when I had a turbonetics t3t4ob .48a/r stage 2 wheel on dsm injectors on 14psi
http://www.we-todd-did-racing....8eeqo
Turns out my turbo was going bad so I decided to upgrade it to a sc61 along with the injectors. This is what my NEW tune dyno graph looks like now....this is on 14psi
http://www.we-todd-did-racing....g6p2f
http://www.we-todd-did-racing....1mytu
Also a/f ratios all over the place ranging from 12.5:1 down to 10:1 at 7000rpms. This was on 14psi!!!!! When I had my t3t4 i was on 14psi. When the tuner tuned it he(I saw this with my own two eyes) copy and pasted values from some other customers maps. Not once did I see him(and i was watching like a hawk) tune any cell alone. But the worst part is now my car will not idle. Cold, warm, or even after its' been driven as soon as I stop it dies. It surges idle for about 15secs then dies. Also anything below 4krpms and anything less then half throttle the car bucks/back fires a little bit. Basically if I want to drive it anywhere I have to be 50%+ throttle and must be accelerating. If I try to maintain speed car will make popping noises unless it's accelerating or decelerating. This was tuned on hondata stage 2b. I went into the dyno with my car running PERFECTLY on crome. But he said he doesn't tune on crome because it blows to many motors. Now I should have said to myself, leave now!..but I didn't and now my car runs like crap. This is the 3rd dyno shop in a row now that has messed up on my tune. Also he said the reason the power drops off like that is because my clutch is bad. Clutch has 800miles on it, I know for a fact my clutch not the problem.
Modified by 90teg at 10:45 PM 5/11/2007
Old Mar 10, 2007 | 04:15 PM
Schister66's Avatar
Man U FTW
who the hell tuned that??? Your AFs look like a roller coaster....
Old Mar 10, 2007 | 04:24 PM
Synapse Motorsport's Avatar
Default Re: (Schister66)
Time for a new tune
Old Mar 10, 2007 | 04:27 PM
90teg's Avatar
The tuner works at the shop.
Old Mar 10, 2007 | 04:29 PM
Schister66's Avatar
Man U FTW
Default Re: (90teg)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 90teg &raquo;</TD></TR><TR><TD CLASS="quote">The tuner works at the shop.</TD></TR></TABLE>
well there's your problem....a blind 6 year old could do a better job
Old Mar 10, 2007 | 04:38 PM
SovXietday's Avatar
Holy torque drop batman!
Um, I did better after tuning my own car for the first time for 30 minutes on the street.
Old Mar 10, 2007 | 04:47 PM
A.E Motoring's Avatar
Default Re: (SovXietday)
damn, that is...damn i dont even know the words for this
Old Mar 10, 2007 | 05:31 PM
PINKS's Avatar
I want a CRX tattoed on my butt
Default Re: (Dual Cam Racing)
You probably even paid to didnt you?
Old Mar 10, 2007 | 05:33 PM
spectacle's Avatar
Default Re: (PINKS)
you're a fool for paying for a tune that horrible.
Old Mar 10, 2007 | 07:46 PM
mtber's Avatar
Default Re: Need help, tuner really did a number on me this time :( 266whp/13psi/sc61 (90teg)
What part of va do you live in ?
I should move out there lol
Old Mar 10, 2007 | 08:17 PM
ngogsr's Avatar
weak
Old Mar 10, 2007 | 08:42 PM
90teg's Avatar
Default Re: (spectacle)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by spectacle &raquo;</TD></TR><TR><TD CLASS="quote">you're a fool for paying for a tune that horrible.</TD></TR></TABLE>
No I didn't, soon as I saw the torque drop like it did I told them to stop. I left very shortly after.
Old Mar 10, 2007 | 08:44 PM
SOHC_MShue's Avatar
the original afr's from dyno inc. area all over the place and i dont know what is up with brauning's tune . Even with the crappy afr's on the old setup the torque curve didn't drop like that. Could be something wrong with the setup or something is big time off in the tune.
Old Mar 10, 2007 | 09:07 PM
Turbo-charged's Avatar
Default Re: Need help, tuner really did a number on me this time :( 266whp/13psi/sc61 (SOHC_MShue)
hmm....i would like to THINK that with a graph that looks that bad there is a mechanical problem not just a problem in the tune. im fairly close to brauning (with in a half hour) send me a copy of your map and i'll check it out to see whats up with it. im a hondata dealer with a inground dynojet as well.
Old Mar 10, 2007 | 09:10 PM
Default Re: Need help, tuner really did a number on me this time :( 266whp/13psi/sc61 (Turbo-charged)
was he using rom editor 3 or 4. i did a gsr this week that made 320whp at 9psi spring pressure with a very similar set up. something is not right at all. shoot me a pm or give me a call i'm curious to see whats going on 301 290 0330
Old Mar 10, 2007 | 11:51 PM
Dueceification's Avatar
have you talked to your tuner? i would talk to him first and see whats up and possibly find a new one. though you cant always blame the tuner first but sometimes you can.
Old May 11, 2007 | 06:54 PM
90teg's Avatar
Default Re: Need help, tuner really did a number on me this time :( 266whp/13psi/sc61 (93b16hatch)
Update on my car, got my car tuned at tempest today. Car made 305whp on 9psi with a boost leak, don't know where yet. Car runs smoother then ever, big thanks to the Tempest racing.
Old May 11, 2007 | 07:18 PM
CRX T-Si's Avatar
H-T to the rescue Turbo-charged
Old May 11, 2007 | 07:22 PM
DfwBB6's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 90teg &raquo;</TD></TR><TR><TD CLASS="quote">Update on my car, got my car tuned at tempest today. Car made 305whp on 9psi with a boost leak, don't know where yet. Car runs smoother then ever, big thanks to the Tempest racing.</TD></TR></TABLE>
finally a better tune tempest
Old May 11, 2007 | 07:55 PM
EJ1 wilcox's Avatar
My basemap had a more consistent AF curve than that. lol
Glad you had it re-tuned.
A train
Feb 9, 2010 06:35 PM
Type-X
Dec 8, 2006 11:00 AM
anothaRRR
Jun 23, 2005 07:54 PM
rbf351
Mar 22, 2003 09:49 AM
PM-Performance
Jun 3, 2002 08:38 AM
