Creaking sound coming from driver side.
Old Mar 10, 2007 | 12:36 PM
The-Kid's Avatar
Default Creaking sound coming from driver side.
Hey there. When I was driving in the morning, there was this creaking noise. But after I drove around for a while, the creaking sound goes away.
I'm thinking the shocks? Is this true?
If theres any suggestion to check, tell me. Thanks!
Old Mar 10, 2007 | 03:55 PM
Tx_Accord98's Avatar
check your lower ball joints. happened on mine.
Old Mar 10, 2007 | 04:01 PM
The-Kid's Avatar
Man! i really suck at suspension. Ummm can you show me? Thanks!
Old Mar 10, 2007 | 04:41 PM
professorman's Avatar
Default Re: (The-Kid)
When I first bought the Integra the other day, there was a creaking sound comming from the passenger side. Turned out that one of the bolts in the engine compartment that holds the spring support was loose.
Old Mar 11, 2007 | 08:48 AM
The-Kid's Avatar
Thanks guys for the suggestions. Well, The bolts are tight at the top. I need help finding the lower ball joint... Help me? =P
Anyone else with a suggestion?
Old Mar 11, 2007 | 08:57 AM
Does it only squeak when you drop in potholes or going over speed bumps? My shocks always squeak in the winter. My shocks are not bad, they just squeak in the winter when its cold outside. I think stock honda shocks are meant to last the life of the car
Old Mar 11, 2007 | 03:43 PM
The-Kid's Avatar
Default Re: (profroopchan)
Aite so heres the whole situation. In the morning, when its cold or something, the squeaks or creaking occurs. By the time I drive around for like 30min+, the creaking goes away.
I'm thinking the shocks, because when I step on and off the gas, the creaking occurs.
I haven't done any lubing on the car. Yet....
This is actually for another car that is not Honda.
HELP ME!!!
Old Mar 11, 2007 | 04:07 PM
Argisht's Avatar
Hey brother,
I doubt it would be the springs as you would have a horrible ride quality if that was the case.
Old Mar 11, 2007 | 08:55 PM
the lower ball joint that i am talking about is the one directly underneath the cv joint. it connects thewhole wheel assembly to together
mark2583
Nov 10, 2008 01:35 AM
'06C-VeekSI
Honda Civic (2006 - 2015)
Jun 19, 2008 02:58 PM
puertoroc7976
Suspension & Brakes
Mar 14, 2007 08:54 PM
