srs light
Old Mar 10, 2007 | 11:00 AM
19992civichatch's Avatar
Default srs light
i just ordered a aftermarket steering wheel, i saw away to get rid of the light on one thred but my search isnt working can someone help me out, or have any other ideas
Old Mar 10, 2007 | 11:06 AM
96 EJ8's Avatar
Default Re: srs light (19992civichatch)
http://www.knology.net/~jediklc/srsreset.htm
Old Mar 10, 2007 | 11:13 AM
thanks but i forgot to put the car is a 1992 eg
Old Mar 10, 2007 | 11:16 AM
96 EJ8's Avatar
Default Re: (19992civichatch)
we used that for a 94 ej1 should be the same. we did it in 4 attempts. its good to have a friend with you to help u out.
Old Mar 10, 2007 | 11:28 AM
thank you and this will keep the light off
Old Mar 10, 2007 | 11:41 AM
96 EJ8's Avatar
so far kept it off for us. give it a shot.
Old Mar 10, 2007 | 02:15 PM
do i have to make one of those by pass things out of the stock plug
Old Mar 10, 2007 | 03:43 PM
does anyone no
Old Mar 11, 2007 | 10:36 AM
do i have to make a bypass plug or can i just take srs fuse out and call it a day?
Old Mar 12, 2007 | 03:56 PM
96 EJ8's Avatar
sorry yeah you have to, we used a pin to do so. I was at work and didnt get to it till today.
Old Mar 12, 2007 | 05:44 PM
so i cut the clip loop the wires and reset the light, or could i dissconect the battery pull the srs fuse?
Old Mar 12, 2007 | 08:18 PM
anyone
Old Mar 12, 2007 | 09:58 PM
Mr Honag's Avatar
I just took the bulb out from the cluster.
Old Mar 13, 2007 | 03:25 PM
96 EJ8's Avatar
Default Re: (Mr Honag)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 19992civichatch &raquo;</TD></TR><TR><TD CLASS="quote">so i cut the clip loop the wires and reset the light, or could i dissconect the battery pull the srs fuse?</TD></TR></TABLE>
no resetting the battery wont do it, unclip the yellow wire for hte srs light from your fuse box, then close the curcuit using the pin you made and follow the instructions on the link I sent you and it will reset your SRS light.
Old Mar 13, 2007 | 06:35 PM
oh thanks man
Old Mar 13, 2007 | 06:57 PM
93eg2james's Avatar
I did this on my Del Sol. Easiest way to do it is to take out the cluster, and unplug the yellow plug. Thats all. Obviously if the cluster isnt getting any SRS info, It cant display a light.
Old Mar 13, 2007 | 07:38 PM
that is true lol
scarsofterroreg
13
Feb 1, 2008 06:28 PM
bb4ninja
Feb 21, 2007 08:25 AM
n2civicsi
Jan 15, 2006 10:32 PM
SiR AuToBoT
Apr 5, 2005 05:50 PM
