throwing code 22 (vtec pressure switch) every now and then....need some help
Old Mar 10, 2007 | 10:26 AM
DC5ftmfw's Avatar
Default throwing code 22 (vtec pressure switch) every now and then....need some help
1st off, I've searched and couldn't really find exactly what Im looking for. Here's the situation: I have a boosted z6. Two times in the past week when I was on the interstate ******* it hard at about 6500 RPM (give or take a little) a CEL has thrown. The 1st time I never got to see what it was because after I turned the car off, it cleared...didn't see it again until I was on the interstate again last night ******* it again. This time I didn't turn the car off. I just jumped it and I got code 22. I can't figure out why it's only doing it every now and then. And I dog it all the time and it doesn't do it. Just these 2 times so far. I have a bad oil leak but I check it daily and add some when it's needed so Im pretty sure oil level is not the problem. Im going to take the solenoid off in a minute and clean it but I don't see how that would be the problem either since it's only coming on every now and then. Anyone have any idea's what could be causing it to throw the code every now and then...? Oh and I doesn't feel like VTEC is engaging anymore either. Hasn't felt like it has in a coupe of days.
Old Mar 10, 2007 | 08:34 PM
onepoint6i's Avatar
Default Re: throwing code 22 (vtec pressure switch) every now and then....need some help (ApexiPwrdEJ8)
check your wireing, more than likely you have a bad solenoid though....
Old Mar 12, 2007 | 09:16 AM
deftonerider's Avatar
expecially check to make sure its grounded, i've never really heard of people have bad solenoids, leaky all the time but bad, not too often
Old Mar 12, 2007 | 10:06 AM
onepoint6i's Avatar
Default Re: (deftonerider)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by deftonerider &raquo;</TD></TR><TR><TD CLASS="quote">expecially check to make sure its grounded, i've never really heard of people have bad solenoids, leaky all the time but bad, not too often</TD></TR></TABLE>
well in the world of automotive i do, plenty of solenoids go bad.....
Old Mar 12, 2007 | 05:58 PM
mrbgartner's Avatar
It may sound rediculous but change your oil... The VTEC solenoid doesn't like to engage when you have dirty or old oil... What happens is the oil gets thin and the computer doesn't "understand" so it throws a code.
Old Mar 12, 2007 | 06:51 PM
Chiovnidca's Avatar
Default Re: throwing code 22 (mrbgartner)
Code 22 point to the vtec switch/circuit. Not the solenoid.
The most common things I see: low oil level, bad switch, clogged screen.
Old Mar 12, 2007 | 06:52 PM
tiredeg's Avatar
this might sound weird but what oil filter are you running use a stock honda oil filter or an s2000 ive had some problems with runnin cheap oil filter and cause that code to come up
ViXoN Hatch94
Nov 28, 2005 01:40 AM
spoonfedGSR
Sep 26, 2003 02:31 PM
JKim0901
May 8, 2003 12:41 AM
Snail Tuning
Sep 26, 2002 05:39 PM
typer_801
Mar 19, 2002 07:08 AM
