oil breather chamber cleanout
Old Mar 10, 2007 | 09:33 AM
dpkelly's Avatar
Default oil breather chamber cleanout
I want to clean out the oil breather chamber on the back of the engine block. I believe it's plugged after 14.5 yrs and 270,000miles. I was going to use degreaser. Any thoughts?
Old Mar 10, 2007 | 10:32 AM
Archidictus's Avatar
Unceasing Measure
Default Re: oil breather chamber cleanout (dpkelly)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by dpkelly &raquo;</TD></TR><TR><TD CLASS="quote">I want to clean out the oil breather chamber on the back of the engine block. I believe it's plugged after 14.5 yrs and 270,000miles. I was going to use degreaser. Any thoughts?</TD></TR></TABLE>
That will work fine, although it would probably be more beneficial to just replace it.
Old Mar 10, 2007 | 11:24 AM
dpkelly's Avatar
Default Re: oil breather chamber cleanout (Archidictus)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Archidictus &raquo;</TD></TR><TR><TD CLASS="quote">
That will work fine, although it would probably be more beneficial to just replace it.</TD></TR></TABLE>
Except it's under the intake manifold and impossible to get to unless you take it off. Damn, I should have replaced it when I was replacing the headgasket.
Cheers.
B16b-EJ8
13
Apr 24, 2007 03:57 PM
top
Mar 19, 2007 01:31 AM
nexgen91
Nov 6, 2006 02:11 PM
axionm1k
Sep 24, 2006 06:20 PM
quazar
11
Oct 23, 2004 05:50 AM
